Anchor chain Swivel Recommendations?
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
When raising our anchor yesterday, we found we had raised a large rock (about 12" in diameter) in the anchor. After I pried the rock out of the anchor, and finished stowing the anchor, I happened to examine the shackle. I found what appeard to be a hairline crack in the shakle. I need to replace it before I go out the next time.
I'd like your input and recommendations on swivels for chain to anchor. We have 400' of 5/8" chain, on a 75 pound Bruce, on a 78,000 pound boat.
Thoughts?
1,606
Frers 33 41426 Westport, CT
I think the general feeling of most people is that the swivel is a weak link that is also difficult to inspect, and should be avoided most of the time.
Agreed, but only if it is an inferior knock-off swivel. You could do a search on the word swivel, with Maine Sail as author, and find lots of discussion about this topic.
zeehag
Mar 26, 2009
3,198
swivels have caused more breakaways in my old mooring field than snapped yacht braid, which is another high level failure in big winds and gusting conditions. goood luck. i do NOT use a swivel.
Dec 29, 2008
806
Found the previous discussion
Found it. Thanks!
Tejas
Dec 15, 2010
164
Beneteau First 36.7 Lake Travis
I think it is possible to somewhat isolate the swivel from stress. The idea is not mine, and I don't recall precisely, but I think I recall it might have been a "Yachting Monthly" article. Between the swivel and the anchor, install three chain links.
Apr 8, 2010
1,606
carlf said:
I have an Ultra swivel. Elegant strong design that does a good job at encouraging the anchor onto the roller right side up. Won't get jammed sideways.
No resemblance to the cheap Chinese pot metal swivels you see around.
http://www.ultraanchors.com/ultraswivel.html
Carl
Wasn't a large batch of those recalled a year or two ago because they were failing left and right?
