An Affordable Chartplotter Option?
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
I have been looking for an affordable chartplotter/gps option that would integrate with the existing systems on my boat. I plan on expanding my cruising range from local waters to as far as Cabo, so I thought this addition would be a good idea, as well as increasing my wife's comfort level. I have a Signet System 1500 wind/depthsounder, and Navico Wheelpilot WP 100 with the ST-4000 autopilot system that was, I believe, standard on Hunters of that era.
I was looking at the following military spec refurbished system advertised on ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170451093416&ssPageName=ADME:X:RTQ:US:1123
I just don't feel competent to evaluate the unit itself, or what options would be good, recommended or ideal for my boat. I wondered if anyone has experience with this or a similar unit could comment on whether this is a reasonable solution, and, if it were, what I might want to add. I was impressed with the size of the screen, obviously intended for a much larger boat. As an example, just one of many I'm afraid, of the magnitude of my ignorance, I note that they will substitute a VGA screen for the LCD at no cost, but was not sure if that amounts to an imrovement or not.
I have the utmost respect for the opinions of this forum and appreciate your comments.
Sep 25, 2008
7,695
Alden 50 Sarasota, Florida
Richard
My only suggestion is to check the version date and datum of the mapping software, neither of which is mentioned as the charts may be outdated or of an incompatible datum to interface if you ever want.
5,802
That's exactly the kind of thing that I have trouble purchasing on E-Bay. Unless it is new in the box AND a product that I have touched I just cannot do it. Better to purchase a used product that you know where someone has upgraded. Around here we use neighborhood Craig's List so that we can go see it.
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
I would not get that.
First off, the specifications do not mention what processor is used or how much RAM it has. Given the probably age of the machine and the short warranty period, I would be very surprised if the system had enough CPU power to run Windows 2000 very well at all. Also, Windows 2000 is a lousy OS for a tablet, as it was never really designed for use on one. Finally, the reliability of Windows for such an important function is questionable. BSODs are far too common.
IMHO, you'd be far better off with a dedicated chartplotter instead. Something like this would be better IMHO.
Oct 3, 2008
325
Beneteau 393 Chesapeake Bay
I took a quick look at the link. This system uses Windows 2000, which Microsoft will stop supporting July 13th this year. Also, as was said, the charts used may be out of date. And I did not see which chart media it uses.
This is not really a dedicated chartplotter for mariners. If you are going to go on longer and wider trips, you should probably budget a good bit more for a real system. Even though I have Raymarine, I would also recommend Garmin. There are a lot of choices. Also, both companies have recently introduced new models, so check out used models from the last 6-8 years that are still servicable.
Dec 2, 2003
1,637
Ask the seller the questions posed above. Also ask about the current consumption on 12V. If the charts are proprietary you will be able to get updates. I would not worry about the version of windows if you are only going to use it for navigation as you will not need any updates.
If he is genuine he will respond truthfully and if not you will have redress in getting your money back. Sellers are nervous about their ratings too.
In the last ten years or so I have used various laptops on board on my nav table and find their capabilities far exceed custom made chartplotters, have vastly bigger screens - and all for a fraction of the price.
Nov 8, 2009
537
Hunter 386LE San Fancisco
I recently installed a Garmin 3210 chart plotter, gps and GMR 24 digital radar for my 1987 Hunter 31. I had a pedestal and mounted an Edson table to it to mount the chart plotter. Alternatively, you can install a new pedestal to mount the chart plotter on. However, these are discontinued products and new ones are way more expensive. Last time I checked the 3210 was $1000 and GMR 24 was $400. New models sell for $2000 each. The gps is tied into the VHF emergency response signal. The chart plotter's split screen shows gps and radar. I plan to use it for night and offshore sailing and foggy conditions. I used them both last weekend when I got caught in the fog in a channel in San Francisco. Big improvement over the Loran I used sailed the Cheaspeake at night and Atlantic. Years ago I sailed from Marina Del Rey to Catalina Island in the fog across the shipping channel on a charted sailboat and would have welcomed a radar and gps.
1,000
I want to thank everyone for their comments. I am going to pose all the above to the seller and see what response I get. I just don't have the money to go with a dedicated chartplotter gps setup, though I wish I did. My biggest concern is making sure that it will interface successfully with my autohelm and the other sensors on the boat. In my ignorance, I assumed that if it was NMEA compliant, it probably woudl do that. I also want it to be able to support radar if I am able to swing that in the future. I don't know what kind of data stream radar puts out, so I don't know what to ask in that regard.
Sumner
Jan 31, 2009
5,254
I hate to be too pessimistic, but I just can't see it doing what you want/need. Where are the inputs/outputs to communicate with your devices? I might not be reading the specs right, but I only see 1 USB port. Is there somewhere in all of that where they say it will communicate with NMEA devices? They say navigation software, but that is a pretty broad term. Is it using NOAA charts? What charts do you plan on using in Mexico and how are you going to load them and will their software work with them?
Go cautiously with this. I'd hate to see you throw your money away.
Good luck,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
Oct 22, 2008
3,502
Without an RS-232 port, the unit will require a USB-to-Serial adapter. While the unit itself may be ruggedized, the USB-to-Serial adapter will not. It is also very unlikely to support radar without some serious investment into software.
The Garmin 3205 or 3206 is available for about $500-600 and will support NMEA 0183 and will work with the Garmin 18HD hi-definition radome. Going this route would make far more sense if you really want the option to expand to radar in the future.
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
USB-to-serial adapters are a pain in the butt: the drivers crash if they work at all. You need something STANDARD if you're ever going to get charts for it. I'd say better an entry-level Garmin than an oddball running Win2k. In fact, if you're going to go the Windows route, you're probably better off with a driveless netbook.
druid
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Choices
You have several choices you can decide from. Quite a few on this board use a laptop, with Sea Clear or Max Sea and a GPS antenna. I have Max Sea with all the charts in my laptop. Biggest problem with this set up is the inability to have it at the helm, or risk moisture getting to the laptop. I have a small (498) Garmin chartplotter at the helm, and use it primarily. The laptop is wonderful for plotting and looking at where I am going, but for actual navigaion, it does not work for me. I am very partial to Garmin stuff, but any chartplotter with NEMA output should work with your other instruments, even though a different brand. You can find some pretty good plotters on ebay, brand new, for ballpark numbers of what you are looking at. As a final thought, if at all possible buy a plotter with built in charts. You will find the cost of the different chips will very soon be more than the cost of the plotter.
Oct 22, 2008
3,502
Even a cheap netbook, replaced twice is going to generally be more of a PITA and cost more than a dedicated chartplotter.
BarryL
May 21, 2004
1,119
Costs
Hey,
A real marine dedicated chartplotter is a lot cheaper than you think. You can get a brand new Standard Horizon unit for under $400:
http://www.anchorexpress.com/ProductDetails.asp?ProductCode=CP180I&CartID=3
A C-Map card for the west coast is another $100.
The unit has NMEA in and out so you can probably interface it to your other units.
If you are interested, Standard Horizon has an emulator that you can download to your PC so you can play with the unit before you buy it, learn how it works, etc.
My last point, it isn't really necessary to interface all your instruments. Since you have wind and depth, why do you need the chartplotter to receiver that information? Same with the autopilot. If you want to navigate to a specific point, use the chartplotter to get the heading, put the boat on that heading and then engage the AP. Monitor it every now and then and adjust as necessary. It's simple to do.
One thing I would definitely buy and interface is a VHF radio with DSC.
Good luck,
Barry
Feb 15, 2010
7
Macgregor 26x Salt Spring Island
I have a Lowrance 3500c used for only one season that I would sell cheap but it would make a better dinghy anchor. When it quit working I attempted to get help from Lowrance but their support does not exist. Their local dealers are embarassed and will probably quit selling the brand. After months of frustration, to lower my blood pressure, I gave up and bought another brand (Standard Horizon). Buy anything but a Lowrance.
Aug 16, 2009
1,000
Again, wonderful comments and the advice that I go slow and investigate all options is sage, and exactly what I am doing. Just a note. I sent the original questions posed here to the ebay seller as follows.
"Thanks for answering my questions. I'm afraid I have a few more, and will probably have some after that, for which I apologize in advance.
1. What is the version date of the offshore charting/mapping software supplied with the unit. Can it be updated or is that done automatically?
2. What is the CPU used in the unit?
3. How much RAM is it equipped with and can that be upgraded?
4. Win 2000 will no longer be supported after 7/10. Can you load a different system as an option?
5. What is the rate of power consumption for the unit when operating on 12V?
6. Can it also serve as a display for on board radar? If so, what would be necessary to accomplish this?"
His answers follow:
No problem. Better to ask before buying instead of making assumptions.
1. 2010. Manually updated.
2. Militarized Intel Pentium III Mobile 400mhz high temperature ceramic cased fanless processor.
3. 256mb RAM. Can be upgraded but requires service by electronics technician and opening the vacuum seal.
4. Some buyers have upgraded it to XP. It is reportedly slower on XP and needs driver updates.
5. 10w to 15w steady state operation, 35w when charging.
6. Compatible radar display software can be installed."
In light of the most recent round of comments, this certainly does not answer all questions. If I remember correctly, the specs included on the ad said it is NMEA compliant and it does have serial ports with an option for waterproof USB addition.
I am definitely look at the Standard Horizon line as it appears to be an affordable alternative. Thanks, Barry.
Oct 22, 2008
3,502
I'd point out that the Chartplotter I referred you to up in Post #4 is far less expensive and comes with the US Coastal charts all pre-loaded. It is only $425 or so vs. the $460 for the Standard Horizon with charts.
Aug 16, 2009
1,000
I had looked at both, Sail. The refurb Garmin is $425 and the Horizon is $361. I am doing some research, but I think you are correct that both are probably better options that the ebay item despite the latter's larger screen. One of comments on a test of the Horizon, which is probably applicable to all 5" screens, was that things can get pretty crowded. The Garmin & the Horizon seem comparable in features, though I will have to be a little more familiar with mapping software and check the many posts on that topic before I can judge which is better. Garmin has a very good reputation, while Horizon seems to be getting decent review.
I also meant to ask about internal vs. external antennas. Is an external necessary only for blue water cruising?
Oct 22, 2008
3,502
Yes, but the Standard Horizon requires that you buy charts for $100... the Garmin has the charts pre-loaded. That's a big difference. One other major point between the two units. IIRC, the Garmin can display AIS data, the Standard Horizon can not. They both have 5" screens, but one is vertical, the other horizontal. The Garmin comes with the sounder, which is an option on the Standard Horizon.
I had the 192C, which was basically the model the 498C was descended from. It was great as units go and if I didn't get a great deal on the 3205C, I'd still have it. I sold it to a good friend for his boat. The internal antenna works just fine. It even worked in the cabin, as I had the GPS mounted on a swing arm and setup so that I could use it both in the cockpit underway and in the nav station when sitting at anchor.
I'd point out that the user interface and software on the Garmin is probably easier to use than that on the Standard Horizon. There is a reason Garmin has such a large portion of the GPS market.
