Albin/Solex parts wanted
115
Newport MKIi 30' Channel Is. CA
Hello Everyone,
I know this may be a stretch, but do any of you have a Solex 26 VBN carburetor that goes on a 71 Albin 022 gas engine.
Thanks
1,154
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
No offense intended but
No tell us what needs fixing -- no fix likely.
115
Sorry, I would appreciate input
Sorry about that, Hers how its gone down
Started ou the motor was reving at times, so I sent fo the needle valve and seat.
Now it starts nice, but after a few miutes it floods and gas comes out the carburetor. Its a bit scarey so I dont run it. I have had it apart twice but no success. I was putting out the feelers for a different Carburetorto try The only upside is I have begun to sail without the motor
Any advice is appreciated
Thanks
Jan 30, 2012
1,154
Float valve is not closing before overflow. Check that the float floats and that the float closes the float valve stem with minimum force. Also, check that bowl fuel level (when fuel level rises - the float closes the valve) is low enough so overflow does not occur.
These things are the fix for the symptoms you describe so far -- Are there other symptoms?
Charles
