I'm intending to keep the Raymarine tridata...still works, hence the concern for all the wires. Just need to replace the plotter. If I get a Garmin MFD I believe there's a Garmin conversion cable that can connect from the old Raymarine transducer. Way easier to clear the house but also more cost and time.you just need 1 power cable and 1 nmea 2000, if you have radar then that's another cable. taken out all the old Raymarine stuff removed 5 cables.
The challenge is mating older equipment (non NMEA) with new gear.
