Shadow, good show, I had a catalina25 swing keel before this O’Day 26. They are good boats I did the first leg of the loop on it a couple of years ago. From Paris landing Tenn to Mobile. I ran into trouble when some sort of heart miss timing caused me to have a series of small strokes. They took me off under extrem protest. Well now on meds to keep all in tune I am determined to go it again. I just bought this O’Day26 CB. It is a bit taller in the cabin and with the center board up only draws 30 inches. One thing I have learned is for inland and coastal cruising the shallower draft the better. I did finally get a sea trail day sailing a couple of days ago. I found a few rigging details I will change. Lead the main halyard aft and install a winch for it. With the fuller headsail both can then handled from the cockpit. The best for a solo sailer. The other must add are stops on the main sheet car track. That slamming back and forth is to much. Also need Jiffy reef line rigged in the main. The hardware is there just no line.
Anyway good luck to you, take my word for it a sail boat will improve your life. Regards, jimmy
