Age 80, O'Day 26 CB, great loop
Mar 20, 2015
3,305
C&C 30 Mk1 Canada
, i mentioned my iPad charger failure.
Do you have the original receipt ?
Call Apple's support phone and they may be able to send you a new replacement.
When you configured the iPad it has you create an Apple ID. You will need that and they should be able to send you one on warranty.
Worst case you can get a replacement when you hit a city with an Apple Store.
Jul 26, 2022
18
Catalina 24 Olney Springs
i am an 80 yr old that has decided i would not spend my last days watching day time TV. So i bought a new to me '85 O'Day 26 CB. will cruise the great loop, intercoastal waterways and inland rivers. as long as i can. It is a good boat for this even many think it is too small. I am just one person and a single hand sailor so i think it is just right. it is only 30 inch draft board up. and 34 foot air draft. I had a near new Tohatsu 25 " shaft 9.8 4 stroke with 4 blade high torque prop I put on it. Boat has roller furl also. I t seems like perfect to me. I just bought an ipad and downloaded AquaMap app. and the inland and coastal charts. i still am getting use to her and putting my regs numbers on. I am still figuring out how to put the headsail on the roller furl as i never had anything but hank on before on severl boats from 30 ' to 22'. I am also still checking out how to get it out of the marina and creek into the ICW at Tuckerton New Jersey. It is aready a great fun adventure. i am bare foot, with sore muscles that have not been used in a while, and having a great time. Good bye shore people and all your BS and disfunction. jimmy
You sir are a man after my own heart. I am 65. Had a TBI from lack of oxygen and can no longer work. I am going out of my mind.
I too have decided to spend my remaining time sailing. I have worked on hundreds of boats but never had one of my own.
I have family and friends on both coasts so I am looking for a trailer sailor. I very much like the Catalina 25. I am only 5ft3in. LOL
I really like the idea of an rv I can drop in the water and plain on zig zaging my way back and forth between the two coasts. Lots of rivers and lakes between the two.
All the best to you Jimmy, Ill keep am eye out for you, Shadowwalker
jmczzz
Mar 31, 2013
538
Pearson 26 fin 4' Tacoma
Shadow, good show, I had a catalina25 swing keel before this O’Day 26. They are good boats I did the first leg of the loop on it a couple of years ago. From Paris landing Tenn to Mobile. I ran into trouble when some sort of heart miss timing caused me to have a series of small strokes. They took me off under extrem protest. Well now on meds to keep all in tune I am determined to go it again. I just bought this O’Day26 CB. It is a bit taller in the cabin and with the center board up only draws 30 inches. One thing I have learned is for inland and coastal cruising the shallower draft the better. I did finally get a sea trail day sailing a couple of days ago. I found a few rigging details I will change. Lead the main halyard aft and install a winch for it. With the fuller headsail both can then handled from the cockpit. The best for a solo sailer. The other must add are stops on the main sheet car track. That slamming back and forth is to much. Also need Jiffy reef line rigged in the main. The hardware is there just no line.
Anyway good luck to you, take my word for it a sail boat will improve your life. Regards, jimmy
Dec 30, 2018
39
O'Day Mariner Plymouth, MA
Great bunch of salty guys here. Thanks for the positive vibes as they say. i am a little confused by conflicting specs on the mast height. the seller said it was a little over 35. sailboat data said 34. The seller who i do not trust to be accurate liked to say the boat was a "rare special model, not a regular 26 CB" but so far i find no separate specs for O'Day 26 CB.
Tie a line to your mainsail halyard and once you have that all the way up, tape the bottom of the line you attached where it meets the deck/top of cabin. I have a "normal" 26' nothing unique with regards to manufacturing or anything. Let me know if you have any questions.
Aug 25, 2024
1
just looking to buy now in the research stage LR
July 6, 2022 Ward (see above post) came over and helped and taught me how to get the headsail into and up the roller furler. Plus he lead me thru the rigging tension adjustment starting with checking the center and square of the mast. What a pleasure to belong to a community of great people that are so willing to share knowledge and give help. Based on the discussion on sail dry lube I bought a can of Maclube. Ward sitting in the forepeak sprayed the headsail bolt rope and guided it into the furler slot as I was out on the dock for a correct angle hosting it up with the trout-line size red tinted line. Ward correctly said to take it slow and steady and do it in small bites of a foot or two. The whole job took a little less than an hour. It is definitely a two-person job. He then stepped me thru centering and squaring mast as well as adjusting the stays' tension. Then it was my treat for a great afternoon lunch at the very popular Dockside Cafe in the middle of the Marina. A blacked fish burrito and fried oyster po-boy made me homesick for NOLA.
Next is installing the 9.8 Tohatsu remote control. I will take some photos of what I come up with and how it looks in a few days. I am determined to go up the Hudson all the way to Montreal and the St Larence seaway. Does anyone have recent experience with mast-dropping realities I have heard about going into the NY canal system?
jimmy mc aboard Nit Z, @ Dockside Marina and Cafe, Tuckerton N.J.
I am late to the party but wanted to find out how your adventure went. Feel like we have similar heartstrings with the sailing, Great Loop, life adventures instead of tv and NOLA. You had me at sailboat but hooked me at NOLA lol! Hope you have many more years full of sailing adventures!
Jun 21, 2004
3,208
Beneteau 343 Slidell, LA
They're identical in every way in sail tracks and no staining. I bought the cheaper Permatex when I was almost out of McLube. Couldn't face the steep price of McLube again.
Ralph,
Did the same a few years ago, refusing to pay outrageous price for sailkote.
BUT, I did a side by side comparison test on a clear glass table top. Sailkote dried to a clear slick film with no residue whatsoever. Other silicone products dried with a hazy residue remaining. Went back to using sailkote again on my sails & blocks; trying to use it sparingly!
