An Aussie friend of mine called yesterday with a problem. He said that in moderate to medium heavy wind, when he closehauled tacks the boat it is slower on the new tack. I thought I knew the answer to the problem right away but had to ask a couple of question to be sure. My first question was had the wind speed change on the new tack changed (answer = yes) and did he adjust the fairlead on the new tack (answer = no). Some controls for the mainsail only control one element (draft depth, draft position, twist and angle of attack) but the jib fairleads adjust ALL 4 elements. So, if you don't adjust the fairlead for the new wind conditions it is obvious the boat will be slower assuming they were set right in the first place on the old tack.So how does a sailor know what the new setting will be on the new tack? The answer is by watching the brake of the sail just before the boat comes head to wind. The jib trimmer reads it and then calls the new setting to the other trimmer. It would be something like two holes up or one hole back. Before the new trimmer trims in the jib sheet, he makes the adjustment unless he has a Garhauer adjustable fairlead system ( with the Garhauer system or any adjustable system he can do it after he trims). If he waits until he has trimmed the jib with a pin fairlead system, the job becomes too dificult.Today, my friend called to tell me how my suggestion worked. He said it worked perfectly and was easy to do after a few practices. I thought to myself - no kidding!!!
