Aft sun shade to use while sailing? (DIY) C-22
Sep 30, 2025
219
Catalina 22 Davis Hollow - Lake Arthur
I've been experimenting with sun shades because I easily get heat stroke and it puts me out for days or weeks after. I got some good designs working along the boom for when I am anchored or docked but what about when I'm sailing? I spend a lot of time on my 1971 catalina 22 sailing for hours at a time and its been hot. Any ideas for a DIY far aft sunshade that I can use while sailing.
I have a sewing machine and am able to put good grommets into material. I've been using tarps for rainy weather and just the regular poly type sun shades for dry weather. Been actually working out great..but have to take down to sail.
FYI I have a back stay that Y's off at about head level (when standing in cockpit) which I'm thinking may be to my advantage for support somehow?
Would love to hear some ideas.
Sep 24, 2018
4,638
Catalina 30 MKIII Chicago
You could run a line from the mast, just below the boom, have it spit off a few feet before your back stay so it's able to tie to both parts of your back stay. You may need a couple additional pieces of line to keep it from sliding upwards when it's tensioned. This could essentially create a boom tent.
To be honest, it might cost the same or less to buy an inexpensive bimini. I'd estimate costs to be around $100-150
I use a sunshade to keep the cockpit clean. It is a big reduction in sun and heat despite the fact that it's more of a netted fabric. I also setup a smaller one between my dodger and bimini while sailing. It's hard to tell the difference between the shade of this $6 shade and the solid sunbrella fabric. I'm sure there's a big difference, but I don't really notice when I'm not paying attention and am stuck behind the pedestal.
There are plenty of people who use oversized umbrellas and are quite happy with them
Good fabric is not cheap so DIY might not be the best route. You will have to take some good measurements no matter what option you choose. My bimini has cut outs for the split back stay. You'll probably have to add them to any pre made bimini
Jun 21, 2004
3,188
Beneteau 343 Slidell, LA
Carl,
You may want to purchase a sample of Phifertex fabric (standard weave) for shading. It is a vinyl open weave mesh that allows some air circulation & blocks approximately 70% of UV from sun. You can sew it & place grommets as necessary. Sailrite can provide info regarding specifications & sewing requirements. Assume that you already have a Bimini top; that is a necessity for sun protection.
BUT, if you are prone to heat/sun stroke, extreme caution is the rule. Choose late afternoon or early evening sailing during summer months. As enjoyable as sailing is, it’s not worth the life threatening risks of heat/sunstroke , during the hottest time of day during summer months. Be careful out there!
Sep 24, 2018
4,638
A wet towel on the back of the neck works really well to keep your body happy in high heat. I once did a job out in Vegas. It was 110F on the ground and we were working on a rooftop. I was fine until I ditched the towel.
Likes: BigEasy
Sep 17, 2022
225
Catalina 22 Oolagah
IMO, nothing beats the wonderful sun-blocking fabrics that we have available today. Under Armor's line of heat gear leggings coupled with long sleeved fishing shirts are comfortable to wear and keep you much cooler on hot sunny days than you would expect. With or without a Bimini, keeping the sun UV's at bay is an investment in your future health.
George
Sep 30, 2025
219
So I do not have a bimini... just some diy sunshades that go over the boom or just under the boom.
Is there a bimini that will shade me in the far back aft cockpit seat while I am sailing? Al the ones I've seen stop basically at the back of the boom and they have to be lower than the boom, correct? ....so they don't throw any shade back of the cockpit.
The wind is sparse most days and I gotta go when its blowin so sometimes I'm out in the hot parts of the day...but if I had some shade over me I'd be fine.
I was considering maybe a big bent conduit pipe that goes up in a big half circle, connects at its top point to were the backstay Y's off and then down and connects to the cockpit sides (where my rear pulpit connects to the cockpit sides) But then I don't know where to go from there, lol Maybe 2 of them that are sort of at different angles?
Maybe just a beach umbrella that I attach to the rear pulpit is the easiest and best solution here. I'm sort of lazy I guess you can say....and ususally spend my time sailing staying on the port side of my boat, unless I really need to change sides. Is this weird or bad or just a personal preference. I'm just crusin...not racing.
Anyone use canvas or coated canvas for an inexpensive sunshade material? If so please sent links or specific brand because there are so many to chose from. I like a lighter tan or grey-orange/grey-yellow/sand/tan-ish color lol.
Bouncing around ideas to have a big flat piece of sunshade hanging down at the same angle as the back-stay with a piece of 3' conduit horizontal at the top and horizontal at the bottom and just keep it up with the extra mast line (top lift) and attach to the backstay at the Y . Make any sense? maybe I can draw a picture.
Interested to hear you opinions on any of this.
Jun 21, 2004
3,188
I thought you were searching for a fabric to fabricate shades for the sides & back of the cockpit areas. If you are looking for overhead protection, Sunbrella is the “go to” fabric of choice. You should talk to a canvas shop; they can design & fabricate a Bimini that will conform to your rig & your specifications for coverage. Yes, it will likely be somewhat expensive; however, it beats getting heat stroke or skin cancer.
Sep 30, 2025
219
Yeah I don't feel I need sunbrella necessarily...although know its great stuff. I also cant afford paying someone to custom make it. I like to diy things and feel a sense of accomplishment and also like the money saving plus I always learn some good skills in doing it myself.
Aug 17, 2013
1,336
Pearson P30 202 Ottawa
If you look an Amazon, you can find already made Bimini’s for a decent price, just make sure you measure twice the width of your coaming so you get the right one, a few inches off is ok, because you can always bend the tubes inwards or outwards a bit (easy with aluminum tubing) for the height, the tubes are easy to cut with a pipe cutter tool (same as in plumbing)
I understand the price of Sunbrella is steep, but it does last a long time, very waterproof while breathable, and available in so many colours.
Happy hunting
Carl there's cheap and too cheap. You posted that you are prone to heat stroke (A Serious medical condition). Crack open the wallet and get yourself some shade. From The Mayo Clinic search on heat stroke:
Overview
Heatstroke is a condition caused by the body overheating. This usually happens because of exposure to high temperatures or physical activity in high temperatures for too long. There are a few stages of heat injury, and heatstroke is the most serious. It can happen if body temperature rises to 104 F (40 C) or higher. Heatstroke is most common in the summer months.
Heatstroke needs emergency care. If it's not treated, heatstroke can quickly damage the brain, heart, kidneys and muscles. This damage gets worse the longer treatment is delayed, which increases the risk of serious complications or death.
Likes: BigEasy
Jun 21, 2004
3,188
Second that motion! Pay a shop to make a Bimini or buy a kit & make your own. Suggest researching designs used by other Cat 22 owners.
Sep 30, 2025
219
I do get it. Sunbrella is the best. Honestly though I get just as good shade from my 10 dollar 6x8' tarp. And the super cheap poly type shade cloth makes great shade for days that its not too too hot.. when you actually want a little sun coming through. Also I am not sure I will like the first ones I make and I don't think they make biminis for that far aft? I want shade at the far aft cockpit where I am steering with my tiller.
Maybe I came off a little too extreme with the heatstroke comment. I had some health issues from being out with no shade at all for days on end on a VERY hot week earlier this summer. That was my own dumb fault but I was ironically experimenting with diy shades and working on other parts of my new(old) boat. With almost any type of shade over my head I'm good.
So all that being said. Anyone have experience or can help with my DIY project. Does anyone have experience with any types of more general canvas or coated canvas as diy shades? Marine stuff is so overpriced and I know there are good materials out there for this job.
Also anyone help me figure out how to frame or support a FAR aft shade?
Aug 17, 2013
1,336
You can mount the Bimini as far aft as you want Carl, on our boat, different than yours, extremely difficult to mount a Bimini on a Pearson P30, backstay, main sheet that almost follows the backstay, boon that goes way back, but we managed to make one, still some fine tuning to do, but I am no longer cooking myself when at the wheel
A Bimini can be mounted as far fore or aft as you need, just look for creative mounting locations.
without seeing your cockpit, railings, rigging… impossible to give options.
On a previous post you mentioned maybe a bent piece of tubing, it can kind of work.
Again it all depends on what you really want, a lot of people don’t really want or understand what can be made and the trade offs that go with their choices.
Do you want a permanently mounted one? Something you can install in a few minutes and easily stow?
if you opt for a “real” Bimini, there are quick release mounts on the market, but where do you store it? It all goes with what you want in the end!
I think an Amazon Bimini (the right size) with a few simple modifications would be great for your needs as far as I understand them. Cheap, simple, lots of shade…
Sep 30, 2025
219
I didn't realize you could mount a bimini that far aft. I always see them up over the companionway and then they need to fold down (towards the bow) ....I move up on deck a lot and have all lines at the mast so I need easy access to hop up on deck when I need to.
Is there a binmini that I could mount as far aft as possible, then fold it down towards the stern? That would be perfect but I never really saw that so assumed it wasn't doable and I'd have to make it myself. Plus cant see how the backstay will work in all this in a configuration like this. This would be perfect thought...to fold up when in use then fold down aft, so that it would sort of lay on top of my rear pulpit. Can you point me in the direction to something like this?
I posted some pics of my boat, sorry no good angles of the cockpit but its all I got right now. I now have a full 1 piece stern pulpit and the backstay Y's off just above the boom height.
