Aft Cabin Leak MH-37
May 10, 2004
254
Hunter MH 37 Manitowoc, WI
First night back on the boat and my wife woke up with wet pajamas. Found a small leak along the top of the aft bulkhead. There is a large cover, which I suspect might cover the steering linkage. I'm suspecting our pedastal or deck cover.
Sep 11, 2011
432
Hunter 41AC Bayfield WI, Lake Superior
If you have an auto pilot with a linier drive there is likely a rubber bellows under the cockpit platform. Mine failed and was letting water into the aft cabin.
May 10, 2004
254
Finally got to clean topside. Found a lot of leaves under the stern locker hatches. Also found the cockpit shower wasn't closed correctly with a gap in the corner. All possible sources. We had a lot less leakage today. I'm going to pull the steering gear covers in the aft Cabin to look for leaks.
May 10, 2004
254
Removed the cockpit inspection cover for the steering linkage. The 4 screws holding the cover were loose and the sealant was sloppy.
