I am in the process of re-bedding all the chainplates and stanchion bases on my 2002 Catalina 310. I have some visible warping and discoloration at the top of the panel above the starboard settee. I've attached some photos. The damage is above the window in the photo and to the left right behind the chainplate tension rod. It feels very dry where the damage is and I haven't seen any leaks. But it sure seems like water damage to me. Once I re-bed everything, my question is might it be possible to remove that panel and replace it with something that at least comes close to matching it? I can see all the screws that would need to be removed and, presumably, so would the internal frame of the window. Any advice on doability and where I might source a panel? Thanks in advance.
