Bob F
I'm purchasing a 98 376 with the adlar Barbar refrig/freezer that has the water pump cooling. Since I live in Phoenix and only get over to SD about 1x/month, do I live the fridg/freezer on 24/7? If so do you leave the water pump on 24/7? Can you run the refridg/freezer w/o the water pump? Or will it overheat? Those of you with this system I need your opinion.
