ADDING ROLLER FURLING!
Jul 19, 2013
388
Pearson 31-2 Boston
I highly recommend using a jib roller furler system if only for the fact that adds and extra 20-30 minutes of sailing time to every to every, it makes getting underway, and then packing up on return, much more convenient.
Aug 28, 2006
578
Bavaria 35E seattle
Have a look at the Alado furlers. Very good and easy to install. They are the preferred brand at a local sailing school here. They're made in S. America and priced very competitively. I was ready to buy one for my 27 footer, but then sold the boat to go larger. C'est la vie!
Likes: Cascade27
JRT
Feb 14, 2017
2,059
I enjoyed the process of my hank jibs on my O'Day 25. I had 3 head sails, a 115, a 150, and a drifter. Changing sails was easy and fun, even worked on a system while racing underway to do it. I even bought a new 115 with reef points and kept the hank on system. Now with my 310 it came with a 135 on a roller. It is supper cool and easy to unroll the sail and rolling up is fast and convenient. But I'm learning it is more challenging rigging a code 0 and makes it more complex.
Your pic shows a yankee bag which I always thought was a nice compromise for hank sail handling. What is your intention with the boat, how long do you plan to keep it? Any thinking of maybe upgrade? I loved my O'Day 25 but after a few seasons I figured out what we needed and saved upgrade money for a new boat.
Joe
Jun 1, 2004
8,258
I don't see how a large, crisp head sail is all that easy to get into a bag. Especially when single handing. It was a PITA just bending it on once. The furler life for me :biggrin:
It can be cumbersome without a specific folding technique. If you're on a mooring... I agree that a furling system is way, way easier. However, at some point you must remove the sail so it's important to know how to get it folded and packed away. If you're at a slip... it's just a matter of pulling the sail off and stretching it out on the dock. Fold from the bottom, pulling each section down accordian style until the head, clew and tack are all on the same side. Then, from the clew end... start rolling the sail, loosely, towards the tack. Insert the bundle into the bag with the three corners on top. When you remover to install... lay the bundle on deck... the tack will be the outermost corner and you can simply clip it on first, then unroll the sail on the foredeck towards the mast... if you're using hanks.... you can straddle the sail and clip them on before attaching the halyard... then tie on the sheets with bowlines... separate sheets make this much easier than one long continuous sheet with a cowhitch. A single sheet works well with dinghy sized boats.... but not so well with boats over 20 feet. (just my opinion, don't get riled up). Besides, leaving the sheet attached and stored in the bag with the sail creates all kinds of problems for the sail and makes the whole package twice as cumbersome. Separate sheets can be run ahead of time... or left in place if you're just changing sails. Can't do that it the sheet is already attached. Okay... enough... you get the idea. Nothing wrong with furling.... but neither should you let the hanked on system cramp your sailing pleasure.
Proper folding and deployment...coupled with separate sheets and a handy jib downhaul can make things pretty damn tolerable. Oh... you must know how to tie a bowline knot.
Jun 25, 2004
1,109
It’s not hard to flake a jib or Genoa on the deck of a boat. Drop the sail, put some tension on the sheet. Leave the Hanks on the forestay. Leave the sheets attached to the clew and pull the clew aft yo one side. Unreeepbe the lazy sheet; coil and crown it. Flake the luff first, alternating the folds to each side. Then flake the Aft part of the sail.
leave the Hanks attached and “brick” the sail by rolling from the clew towards the bow. Tie the brick with a sail tie. If you store it on the foredeck, put the jib bag on now. If you store it below, unclip the Hanks and stow it in the bag.
When you want to go out sailing again, remove the cover. Set the brick on the bow between the pulpit legs. Reeve the sheets through the blocks. Remove the sail tie and use the sheets to tie a slip knot to keep the sail on the bow. If it’s windy, this will keep everything ondck with minimal windage. When you are out of the marina or anchorage and or ready to hoist the headsail, , yank on the sheets to untie the slip knots, pull the sheet to unroll the jib, and hoist the jib halyard and trim the sheets.
If the wind is light, you can unroll the headsail to lie on the side deck before leaving the dock or mooring.
It takes time to do all that, bit it’s pretty straight forward. A furler is more convenient for frequent day sailing, because it takes less than a minute.
Likes: jon hansen
Apr 2, 2020
16
Cascade 27 Olympia
When I bought the boat my main intentions were to get something that was ready to sail and allowed me to get out on the water without having to spend a lot of time fixing and repairing. Now that I know more of what I appreciate on a boat, like, don't like, etc. I found that I'm leaning towards eventually getting something in the 30' range with a wider beam. I just want the extra space but don't want a massive boat. 35' would be the max I would want to go. I'm weighing out the cost of all the upgrades I would do vs just buying a boat that has those upgrades already in place.
Likes: JRT
