What are my options for adding a tach to my diesel? YSM-12. I need to find the proper prop pitch and I can't do it with out a tach.
I have a hitachi 35 amp. The original to the motor.Do you have an alternator on your boat?
So, most diesels with tachs use the alternator "tach out" for a signal to the tachometer. As I recall, you have a Yanmar engine in your boat, rather than the standard M25 diesel, so I look to the Yanmar guys to help out here. But alternators are all pretty much the same: find and run the tach out wire to the tach, ground the meter and you're done.I have a hitachi 35 amp. The original to the motor.
