Adding a chartplotter
toddco
Jun 17, 2011
96
ODay 20 driveway
My bride is getting me a chartplotter for Christmas. My Oday 20 had been completely stripped. There is almost nothing electrical left in the boat, other than two nice bilge pumps. My thought was rather than add a compass, depth sounder and speed indicator use a chartplotter for all. What is the best type of transducer for a trailer sailer? Thru hull, shoot thru hull, or exterior mounted?
Thanks for all opinions, and Merry Christmas everyone!
Todd
Sumner
Jan 31, 2009
5,254
How much does she love you.........how much will she spend on you?
I'd get a shoot thru the hull. Other things to consider is if it quits are you sailing someplace that a compass would come in handy to get home? The speed will be probably over ground. That works for us, but you still need to be aware of currents and such on the boat if they apply.
We use SeaClear with NOOA charts on a computer and love it, but if I was buying a unit I'd probably get a Garmin 4" or 5" with a transducer (if I could get a shoot-thru for those models) and get one with charts for where I was.
Merry Christmas,
Sum
[FONT=Arial, sans-serif]Our Endeavour 37[/FONT]
[FONT=Arial, sans-serif]Our Trips to Utah, Idaho, Canada, Florida[/FONT]
[FONT=Arial, sans-serif]Our MacGregor S Pages[/FONT]
[FONT=Arial, sans-serif]Mac-Venture Links[/FONT]
toddco
Jun 17, 2011
96
ODay 20 driveway
Not that I peeked, it is a Humingbird 788. It comes with a trolling motor mount, but it can take a thru hull or a shoot through hull. The lakes I'll be on, the compass and currents aren't really an issue.
As for how much does she love me? I figured she's put up with me for 20, I'm probably good for another 30-40 yrs and then senility will kick in.
Todd
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
76cx
WM had a deal a while back for the Garmin 76CX and a g2 for allUS really cheap so that is my new back up and I use it Kayaking also and it gives almost all the info my Ray C-80 gives,I use it on my Notebook for routing too and backup Charplotter with Homeport and Map source.
Nick
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
Trasnsom mounts can get knocked around, and I hate drilling holes in the boat, espically the bottom, so I would go with a shoot-thru, which should be fine in a lake.
Although I don't need it for navigatin either, I would feel naked not having a compass. What if the plotter was out and you were in a dense fog?
toddco
Jun 17, 2011
96
ODay 20 driveway
Ken,
This is my starter sailboat, I still have my old backup handheld garmin and handheld compass.
regards,
Todd
Oct 26, 2005
2,057
- - Satellite Beach, FL.
Sailors were mounting transducers intended for stern mounting inside the hull long before the manufacturers caught on. I have a thru hull type transducer (bought for a different boat and never installed) mounted with toilet wax and it works great.
I'd just use the transducer that came with your plotter.
Cool machine BTW! You must have been a good boy Toddco!
toddco
Jun 17, 2011
96
ODay 20 driveway
Wow, Thanks for the tip! Does yours have a water temp probe and where in the hull did you mount yours? My inner hull is completely accessible.
I was told that wives like to check water temps prior to jumping overboard.
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
I know this doesn't help, but your probe question popped a memory:
Back in the 70's aboard SES Malolo, we were required to make a log entry every hour. It included the weather conditions. We lost several buckets attempting to get sea water to read the temperature. I came up with an alternative solution. Pump fresh seawater into the head and take the temp there :)
Ever hear of soap on a string? Get a thermometer at ACE Hardware, and tie a string to it.
You could put it in the head or overboard. :)
Your boat, your choice.
Oct 26, 2005
2,057
Mine is just a fishfinder. I like the head bowl method for taking temps! that would save on poking holes in the hull.
I mounted my transducer as far forward as I could, centerline and low enough to still be underwater in a decent chop. On my boat this was at the V of the vee berth. forward of that point is a water tank.
Where will you mount the plotter? Sumner has devised a great rig for his that you can see on his website.
I've never gotten my wife to jump over the side but she's thrown me overboard a couple of times:D.
toddco
Jun 17, 2011
96
ODay 20 driveway
I think I saw his rig. It was on a swing arm that folded into view or back into the cabin. That looked like a great solution. That is my current plan.
Hunter 26 Illinois
Transducer
Todd,
I have a Lowrance chartplotter and it's great. The transom mount transducer can indeed be epoxied to the fiberglass hull but it will not penetrate more than 3/8 inch of fiberglass no matter what the instructions say. Guess how I know this. I now have a routed rectangular hole in my hull that the transducer is epoxied into. Secondly you cannot use an epoxy that has bubbles in it after it sets. Guess how I know this also. I used this marine epoxy from Ace hardware http://www.acehardware.com/product/...poxy&origkw=marine+epoxy&searchId=54239657464
because it is very thick and does not have bubbles. It has worked just fine. Once I had it in place and knew it was working I finished filling the area around the transducer so the hull is solid.
Likes: 1 person
Nov 19, 2008
2,129
Catalina C-22 MK-II Parrish, FL
We don't have a chartplotter, we just use our Garmin Nuvi that we use in the car. I just put it in off road mode. Made a cheap little swing-out mount from a hook assembly I got from Home Depot and some rubber cable mounts. On our current boat, we just use the suction mount on the cabin bulkhead. We used the Nuvi for our off shore navigation, and in the harbor, the shoreline map is pretty accurate. It's also easy to load all the buoy locations from the charts.
Don
6,990
Only one comment on the lack of a compass. GPS is all fine and dandy but it has this latency thing during the update when going slow. The direction it says you are going is not consistent . so what instrument does the helms man use to hold a steady course? Perhaps the shore is always in sight and this is not an issue. What about low visibility days?
May 25, 2004
981
CaptDon01,
I did something similar on my Cat 22. I used a hardwood swing arm that attached to the underside of the cockpit. It swung into the bottom center of the companion way. I just gave it a little push to go below.
I mounted a fishfinder I picked up reasonable from Gander Mountain. A great tool for sailing on a river lake where dead heads are the biggest hazard.
Sumner
Jan 31, 2009
5,254
Our boat came with a fish finder/depth finder....
....mounted in the bulkhead at the head of the cockpit. It was ok, but not good when anchoring especially in some light conditions. We anchor every night and usually on a new anchorage. As we approach a likely anchorage I go forward to the bow to deploy the anchor. Ruth is on the tiller as per usual and she tells me water depths as we move towards where we 'think' we want to anchor. With the depth finder so far forward of where she was it was hard for her to see the depth on it especially in some light conditions.
Now with it on the lifeline...
...right next to her she can see it easily.
If we are in other shallow water just motoring or sailing we can slide it forward on the ....
....lifeline like above and I can keep an eye on it. If we are going ashore for a couple days or leaving the boat on the trailer someplace on the road or at home it just unplugs and unclips and goes below.
We are really happy with this setup now. On a larger boat like our Endeavour the life lne is too far away from the helm, so on a boat with a wheel you would want it mounted where it is easier to see for whoever is at the helm and that is what we will do with that boat. For a trailer sailor though with a tiller the ..............
http://purplesagetradingpost.com/sumner/macgregor-navigation/Cuda 350.html
...........lifeline mount is really nice,
Sum
toddco
Jun 17, 2011
96
ODay 20 driveway
Thanks All for the great advice. Sumner's boat looks like it may have a little more dancing room than my 20'. I was planning something like CaptDon's swing arm. As for low visibility, I still have my handheld map reading compass. The odds are that I will not be out of sight of land in Southern Illinois or Western Kentucky.
Merry Christmas,
Todd
544
Bristol 43.3 Perth Amboy
Merry Christmas,
Todd
Map reading compasses don't do well when it is rough. You could and should have a real compass on board. You can find one on eBay for really cheap.
On my old boat I had a simple solution for a mount for a plotter. I mounted the unit on a piece of wood that was shaped like an upside down L. On the inside and outside bulkhead I mounted pieces of t track. The head of a 1/4 20 bolt mounted thru the wood slides into the track. Wing nuts to tighten. This keeps the unit out of the companionway.
Happy, merry!
