Reefing Track
BobIt's hard to answer your question because we don't know how long your particular existing track is. We also don't know where you're putting your second reef clew grommet.I suggest that you measure it yourself on your boat. What you're looking for is to find out if the track goes far enough forward so that when the second reef clew grommet comes down to the boom there is abut a 45 degree angle on the reefing line between the grommet and the block, similar to what you have for your first reef.The blocks are easy to find. Most Catalinas I've seen have Schaefer blocks. Any marine store, or online, will have them, just match the same block you already have with the built in horn to hang the second reef line on before it goes up to the clew grommet. Make sure you measure the width of the track and match the block to it.Stu
