Acrylic Windshields
Looks like a previous conversation is closed.
I have to replace my windshield. It's nearly flat with a slight curve. Can flat stock work? Who has. Gone though this ?
Any help thanks?
Here is a copy of an e-mail from (at that time) Hunter Marine. They make it sound quite simple.
_________________________________________________________________________
Ralph,
The fixed are not quite as easy as the lenses on the opening ports.
If there are any screws ,remove . Cut the caulk all the way around,
and slip mono filiament line under and pull around to cut all caulking
loose.Then of course to replace, all the old caulking needs to be removed
for a clean surface.
Thanks,
Ronnie Barnes
Replacement parts are sold with a 30 day Limited Warranty.
Electrical and underwater components are sold with NO warranty.
Shipping and delivery dates CANNOT be guaranteed.
What concerns me is the large landings that the acrylic is glued to with Dow Corning 795. I think that's going to be a real bear to get that mono filament line all the way under the acrylic.
I've already replaced the acrylic in all of the Lewmar hatches and I know the old 795 in those was an absolute SOB to remove :cussing:. It was only about 1/4" wide and quite open but still very difficult.
I've been grumbling about replacing the fixed windows for a couple of years now and it's just matter of making the first cut to get the job started.
PS Flat stock is fine for the job. Use a few small screws to hold it in place while the 795 sets. Remove the screws after and fill the small holes with 795 for appearance. This was how mine were factory installed.
