AC unit in main salon
Jul 29, 2014
37
beneteau oceanis 45 south haven, mi
Cruisair low pressure alarm. My salon unit on my 2014 45 has started cutting out and shows a LO/PS alarm and shuts down
Aug 4, 2015
32
Oceanis 45 Chicago, Montrose Harbor
When I've had trouble with my system it usually is the strainer for the water pump intake. Close the through hull valve, open the top and check the strainer ...
Jul 29, 2014
37
My AC man was just here and thinks the heat exchanger is obstructed. The strainer is clean. He is going to backflush the system. At least the compressor checked out ok.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
these onboard ac units will drive you crazy until you learn how to troubleshoot them...... but it is nice to have one onboard
Gunni
Mar 16, 2010
5,937
Common alarm for poor raw water flow. My AC guy installed an upgraded Groco raw water strainer and coached me on regular filter cleanings and seasonal flushing. I configured a hose barb to fit the raw water hose and flush with a freshwater hose at dock side. The raw water circuit accumulates a lot of gunk sitting there running in the marina soup. Even found a herring wedged 6" above the through-hull. Keep a clean machine.
Likes: JamesG161
Jul 29, 2014
37
Back washed the sea water line today. Flushed out a half cup of muddy gunk. Unit works great now. The Groco filter looks like a good addition.
Likes: JoeRickard
Jun 1, 2016
24
Beneteau Oceanis 45 Palm Beach
I have an Oceanis 45 in South Florida. We have to clean the A/C strainer at least weekly. We also had a problem with grass and debris blocking the generator intake. (That was after we cleaned the strainer) The blockage was where the through hull goes through an "L" fitting. I closed the seacock, removed the hose, and cleared the blockage. All is now well.
Jun 15, 2015
4
Beneteau Oceanis 45 Kemah
Our 2015 OC 45 has been 3 years in Kemah TX and is now in Stuart FL. The AC cooling circuit has been an issue since the first season. As well as keeping filter clean I regularly flush the system using the Sea Flush Filter kit and snorkel. It’s $100 at Amazon, seems expensive for a couple of plastic funnels and a couple of bungee cords but it fits all the suction strainers perfectly. I get a 5 gallon bucket with a 10-20% Muratic acid fresh water blend, stick snorkel in bucket, switch system on and pump the 5 gallons through the system. Refill with fresh water and a bicarbonate soda mix to neutralize acid. Full flow is restored. Do it every 6 months or as required.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Pulled a jelly fish out of my strainer last season. So when you back flush the system do you stick hose in the “out” fitting and just pressure flush system backwards??
Thanks
Greg
JamesG161
Feb 14, 2014
8,017
Hunter 430 Waveland, MS
:plus::plus:
Me too!
Until @BigEasy showed me this cool Groco adapter. I added a female to female quick disconnect coupling to top and make sure the water pressure stays below 25 psi.
Once you get it to flow well, you can add 2 of these to the strainer basket for a good treatment.
https://www.walmart.com/ip/Clorox-Pool-Spa-Small-Pool-1-Chlorinating-Tablets-1-5-lbs/41465552
My Dometic, Marine Airee, etc made units have their heat exchange made of cuprous/nickel just like a hot tub uses as a heater. They are subjected to the stronger Bromine tabs.
During the summer months it keeps my AC lines clean and exchanger at top efficiency.
Jim...
PS: No Groco, then I still have a this to use as the "push in and hold"....
https://www.walmart.com/ip/Garden-L...-Nozzle-Sprinkler-Head-Water-Sprayer/46567791 per Gunni.
