Pump runs continuosly. Provides plenty of water pressure but does not cycle off when compressor shuts down. Unit is a new Mermaid 16500 BTU reverse cycle unit. Have checked all wiring and have gone through reset procedure with thermostat. Manufacturer tech support believes it to be a thermostat programming issue and is sending a new unit. However when I remove the thermostat from the system pump continues to run. Any ideas?
