AC (120v) Panel
jrezab
Sep 2, 2011
26
Pearson 303 New Bern
Ref. 1986 My Pearson 303
My AC panel for shore power has a red led light to indicate when there is reverse polority. Should the led light up when shore power is connected and before the main AC breaker is turned on or after the main AC circuit breaker is turned on?
Jerry
Windy City (#314)
New Bern, NC
They are generally wired thru the breaker, and will only work when the AC breaker is ON.
Sep 25, 2008
7,565
Alden 50 Sarasota, Florida
If I take the question literally, the red light should never be on. If it is, you have a problem between the N and Grd.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
Red light should not go on regardless... if it does you have a problem. Yellow light will not come on till you turn the breaker on with shore power connected.
