A Year of Fouling and Half Knot Speed Loss
3,562
Endeavour 32 Portland, Maine
This is what it looks like:
The VC17M paint actually stayed very clean for most of the year. There was no detectable speed loss until about six weeks ago. Once the copper wore out, the water got warmer, and I wasn't underway as much, things started to grow.
Probably 75% of this growth just happened since I arrived back in Maine. Speed under power was down 1/2 knot but we were still making over 6 knots on a broad reach during the last daysail the day before haul out.
Nov 6, 2006
9,894
Quite a vegetable farm, Roger.. but Warren wins some kind of "grower of the month" award..
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
Jeez Warren looks like a Chia Pet....how long were u in water , where, and what kind of paint????? Red
You did that whole trip with a 2 blade prop? Anyone coulda told you you'd never make it. :)
zeehag
Mar 26, 2009
3,198
omg--ye can still see boat hull--your garden is deficient.
TAK
Nov 29, 2009
47
Beneteau 381 Punta Gorda
Warren, please tell me that is not actually your boat and Herring Bay growth. It looks more like some tropical jungle growth. Regards from HHS.
Nov 22, 2008
3,562
Sure. Strider bucks into a head sea as well as any trawler yacht. A prop is inherently more efficient the fewer blades it has. As long as you have sufficient clearance, a two blade prop works just fine.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Can I expect that much in fresh water?
Probably not. I'm in fresh water and the VC17m does a pretty good job. I get a bit of slime and some crusties along where the keel & hull meet, especially on the shady side (go figure) but nothing that doesn't wash off easily.
Jan 27, 2008
3,045
ODay 35 Beaufort, NC
Sorry Roger I can't resist. If this is true then as the number of blades approaches zero will my sailboat plane like a motorboat? :>) What happens when you get below 2?
Oct 2, 2008
3,807
Pearson/ 530 Strafford, NH
Does this mean the dock space under the bridge is open? Will it take long (or Long) to scrape it clean? So many questions.
All U Get
3,562
There have actually been some experiments, primarily with wind turbines, using a single prop blade and a short stub with a counterweight. Efficient but long. If I were to try this on my boat, the blade would need to be twice as long which would require a rather extreme shaft angle. That would offset any theoretical gains.
It isn't number of blades that is important but blade area. When this is restricted by available space, increasing the number of blades increases the area. Most sailboats have the space available for a prop restricted enough that they do better under power with a 3 blade. The E32 has enough clearance for a 2 blade to work well.
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
While a single blade is scientifically and factually most efficient, the complications have remained difficult to overcome. They have even tried single blade rotors on helicopters.
A 2 blade boat propeller is more efficient, but a 3 blade is quieter and smoother. Its a compromise.
