So my easy boat job only took all day Sat. I just got my main back with logo and numbers installed along with the new stack pack. Simple job, install lazy jacks, stack pack and the main sail. How hard could it be. The lazy jacks are my design based upon a previous owners setup, I have mounts on the mast for the blocks, every thing is cut and ready for a few bow lines. Good to go.
Now up the mast, should be simple, folding steps are in place and I've only got to get to about 45' on the mast. Setup the bosuns chair, start climbing, uh oh, any idea how hard it is to climb a raked mast. Wife does a nice job of tailing with the main halyard(only line I have so sorry, no 2 line safety net). Finally make the climb, way out of shape and breath. Now to install the two blocks, 1/4" ronstans with as all screw to remove and replace. Wow manage to do both without dropping one (knock on wood). Install the lazy jack lift lines ( didn't drop that either). Down the mast, sorry didn't get the steps closed so they are now open for my later climb up to add a wind sensor.
Hmmm, not your typical boat job - so far so good. Now to install the stack pack and sail. Cool everything looks good...oops forgot the sail slug for the loose footed main, remove stack pack, remove lower full batten, ahh now can put the sail foot slug into the track. Cool everything is good...oops. Stack pack sail on wrong side of sail slug... Remove stack pack, remove sail slug, remove batten, reinstall.
All in all, not too bad. Only one trip up the mast, only 3 times to install stack pack and sail, now to figure out the mizzen, did I mention I need to install a ne radar done and for some reason we don't have st ps on the mizzen mast.
Anyone got good ideas for how best to get up that mast? Only need to get to the spreaders and then I'm good. Any hope I can get 2 more blocks installed without dropping at least one pin.
Now to remove the old radar and cabling, feeding that through the cabin, engine room and rear bath room should be fun.
