So when I uncovered my runabout, preparing it for sale, I found the bow lights not working. Then I remembered that while covering the boat in the fall I found a loose crimp on the switch (Cole Hersee 3 Position push/pull). I just cut the crimp off and bent the wire around the screw and tightened it - delaying the job for spring. So that must be the problem. Wanting to try to do things right I decided to get my crimp stuff and put a ring on the wire. So I crimped a ring on it and unscrewed the brass connection screw to put the ring on - right? As readers with experience might anticipate, I could not get the screw back in it's screw hole with the ring around it,
up under the dashboard with the sun hitting my eyes at the exact angle to be able to view the switch. So I dropped the screw five times. 4 times I could easily recover it. Number 5 - no. The screw is gone to the great beyond in the space between the floor and the hull. It will probably work it's way back to the bilge sump and foul the bilge pump float switch but that will take years. Meanwhile I have a buyer coming to look at the boat this week.
I don't really expect an answer but wanted to vent my frustration. But if anyone can tell me the specifics to buy a new screw, it would be nice. Otherwise, I'll do what I should have done, which is to remove the switch from the dashboard and re wire it in my lap . Now I'll have take it to the hardware store and hopefully not have to buy a new switch for the boat I am selling and didn't get enough money for. And that's how a simple boat job goes.
