A couple more dinghy questions
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
I ended up ordering an 8.5 ft inflatable dinghy which I should have before this weekend and I am really excited :dance: I went with a pvc model that will spend most of the time in its bag but i'd still like to protect it when out in the sun. A West Marine associate highly recommended 303 protectant. Anybody use this stuff or have a better recommendation?
Also, how to tow... The dinghy has three rings. One on the bow and two a little further back on the port and starboard sides where the hull widens. When towing are all three rings used or just the bow? Also is the towing line generally permanently tied to the ring(s) or is a shackle used?
Thanks!!
Manny
caguy
Sep 22, 2006
4,004
Manny, here is a pict of one of the 6' bridles that I made up for towing. It works pretty well. It goes from one of the side D rings on the dink to a loop on the end of my spring line. The other end of the spring line is looped to the end of the painter. The spring line keeps the painter from yanking on the raft and stressing the D rings. The other end of the painter line is run through the horn cleat and the bitter end is knotted just in case it comes uncleated. The poly rope is difficult to knot but it splices well. The snap shackles work well at the dinghy landing. The whole setup was put together for less than $15 thanks to Minney's.
Did you get the Baltik, if so I think you'll like it. On the first day a friend tied it to the trailer at the ramp then told me to go park the car. After dragging it about 100 ft. it only scraped a hole in the floor at the transom. The boat still performed well despite the leak. When I got it home I patched the floor and added a ss skid plate to the bottom of the transom.
As far as the 303 is conserned I picked some up to use on my furler cover and never thought about using it on the dink. I think I would try it out on the piece of patch material, that comes with the boat, first.
3,502
- Telstar 28 Buzzards Bay
Very good stuff...make sure you get the Aerospace Protectant, not the fabric waterproofing stuff.... :)
Thanks!!
Manny
The outer two rings are normally used for a towing bridle, and it makes a lot more sense to use a bridle than a single tow line, since it will make the dinghy far less likely to break free... :)
Beneteau 323 Annapolis MD
Manny, I would tie two lines to your transom, then run them through the P & S ring and on to your towing line. This takes the strain off the 2 rings, which are then acting as a fairlead, more or less.
Oct 22, 2008
3,502
Ron's suggestion is a very good one, especially if you tow the dinghy significant distances... however, many do not have any decent points to tie the lines to on the transom.
Manny
Oct 5, 2006
983
Thanks guys! Great advice as usual!
Frank, after much consideration I ordered an Aquamax dinghy. One of things that I liked about it was that the bow is not as "pointy" as the baltik or others, so there is a little more space up front. Price was a factor too. Also the associate I spoke to over the phone took the time to call me after hours and spent a fair bit of time answering all my questions and explaining the differences between some of the models. We'll see how it holds up.
Manny
Sanman
Aug 28, 2006
109
- - Birmingham, AL
So How has it held up? I just sold my walker bay, and am looking at inflatables. Has the boat performed as advertised? Did you get the tunnel hull Sport type or did you go with the rounded bow standard "Tender"?
Sumner
Jan 31, 2009
5,254
Tow Bar for the Dingy.............
We use the two bow lines on the dingy like the other guys have mentioned. I have them tied to 3 chain links where they come together. Then I hook the tow line to the middle chain link with a carabiner. The two lines attach to the dingy with snap hooks, so it is quick and easy to remove any or all of the lines.
We use to tow on a tow rope with the dingy some distance behind the boat. That was a real pain. If you stopped and didn't pull the dingy up close to the boat it would drift around and tangle the line on the rudder and the outboard if it was down.
Then I used the swim ladder as a ..........
.............. tow bar. The dingy's bow line pulls right up to the tow bar and it can't drift around and run into the back of the boat or prop on the outboard.
To do this I just had to make one......
.... bar that holds the ladder up so that it sticks out horizontal to the water and I made a ..................
....bracket for the bottom of the ladder for the tow line to go through. We don't use that poly line for a tow line anymore. It is too skimpy. We use an older halyard line that we replaced. There can be quite a bit of strain on that line.
If we want the dingy out further just let the tow line out or pull the dingy up to the ladder. We have it up close for most sailing conditions and it works great.
This is a simple mod if you have a ladder like ours and now we never mess with the dingy and it doesn't mess with us. The build is here.....
http://purplesagetradingpost.com/sumner/macgregor/outside-17.html
An added bonus to this is with the swim ladder horizontal it is like a platform and much easier for Ruth to get in and out of the dingy when you pull it along side.
Want the ladder down. Pull a pin on the bar and unhook the bar and put the ladder down. To run the line through the bottom of the ladder you pull the ladder up to the stern and snap the tow line through the carabiner and then lower the ladder and re-hook it horizontal with the bar. Very simple and quick.
c ya,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
Sumner, that's a slick towing setup. That's the kind of thing that is good to see on these forums- someone else's brain at work ;)
zeehag
Mar 26, 2009
3,198
we sail with ours on the bow--many folks have found free dinks floating in the oceans-some even with engines....goood luck to ye.....
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
Depending on your expected demands, one option for towing is to install eye bolts into the transom of the inflatable on both sides of the transom. Run lines forward from each eye, along the sides of the tubes, through the eyes on each side of the forward tube and into a bridle to the mother ship. This takes all the stain off of the eyes that are GLUED on to the hulls and transfers it to the wooden transom that is now pushing the rest of the dinghy - not pulling it.
Manny
Oct 5, 2006
983
So far so good
I got the HDR 8500 which is the rounded front tender type. I am pretty happy with it. My only complaint is that there is a very slow leak in one of the tubes that I'm pretty sure was there since new. I've been trying to track it down and can't seem to find it :doh:. Other than that it's been through quite a bit and is in great shape. It's travelled around a lot of the upper Chesapeake :dance:. I got lazy and kept it inflated and in the water all season, being that it's pvc I got 303 protectant and used that plus I bought and used a nice cover that matched the canvas of the "mother ship" perfectly. I haven't noticed any degradation of the pvc after one season. The instruction booklet said to use all three rings for towing, what I did was create a bridle that attached to the outer rings and pulled it through the middle ring. It tows very well and if it slowed our little 27' down, I didn't notice it. No noticeable problems towing it from port side of the boat so as not to tangle with the outboard on the starboard side.
Rowing long distances was hard work after a while :cry: but it wasn't too bad. Hopefully by next season I can buy a nice little used outboard for it. I did try a 3 1/2 hp on it (its rated up to 8) around the marina and it was a blast. It seems like the perfect size for it. It feels very stable and I am happy with the air floor.
If I were to do it all over the only thing I would change would be the size. It was recommended to me to get the 8' 6" model but it turns out to be much bigger than I needed.
Manny
Manny
Oct 5, 2006
983
Oh yeah - Sumner, that's a pretty cool setup using the ladder!
Manny
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Walker Bay
Sanford, may I ask why you got rid of your Walker Bay? Was there a problem with it?
larryw
Jun 9, 2004
395
Beneteau OC400 Long Beach, CA
those fabric protectants will make the tube so slippery you can hardly sit on them
Nodak7
Sep 28, 2008
1,256
Ron do you have this set-up? I read this and thought it to be an excellent idea. My D rings are showing a little wear from being towed. However, I would have to put a couple of I bolts in the transom to do this? Do you think that drilling a couple of holes in the transom would compromise its integrity? Also, by doing this is it putting to much strain on the joints between the transom and the inflatable tube?
If you do use this system could you give me a little more detail? Is it actually two lines or one going all the way around the dink through the D Rings?
Ron do you have this set-up? I read this and thought it to be an excellent idea. My D rings are showing a little wear from being towed. However, I would have to put a couple of I bolts in the transom to do this? Do you think that drilling a couple of holes in the transom would compromise its integrity? Also, by doing this is it putting to much strain on the joints between the transom and the inflatable tube? If you do use this system could you give me a little more detail? Is it actually two lines or one going all the way around the dink through the D Rings?
Higgs in reply #12 expanded a little bit more, and is the same idea. We assume your dee rings are on the top of your tubes, whereas Sumner's are down by the waterline. Yes, there are two separate lines from the transom to join at the towing bridle. I thought I posted this reply before, but maybe on a different thread. An outboard mounted on the transom would also torque-twist the transom-to-tube joint, but the joint should be pretty well reinforced- I'm sure all dingies are- so towing should not be a concern... If you drill holes through the transom, use some sealant to keep water from migrating into the transom. There are a few products that transoms are made of, but sealing holes in any type would be a good idea. Though my dingy came with u-bolts thru the transom, I changed one of the nuts to eye nuts. If you're starting anew, use eye bolts on one side, and eye nuts on the other. This gives you some extra tie points. Even if you tie the dingy down on the bow/deck, you'll appreciate the external loops on the outside of the transom. Of course, use fender washers or some type of backing plate on BOTH sides of the transom
Oct 22, 2008
3,502
I'd point out that if you're towing a dinghy, it is usually a pretty good idea to remove the outboard from the dinghy first. If the dinghy flips or gets swamped, it would become a rather expensive problem if the dinghy's outboard is on it... rather than just a nuisance if the outboard is safely stowed on the mothership's rail.
