Tow Bar for the Dingy.............
We use the two bow lines on the dingy like the other guys have mentioned. I have them tied to 3 chain links where they come together. Then I hook the tow line to the middle chain link with a carabiner. The two lines attach to the dingy with snap hooks, so it is quick and easy to remove any or all of the lines.
We use to tow on a tow rope with the dingy some distance behind the boat. That was a real pain. If you stopped and didn't pull the dingy up close to the boat it would drift around and tangle the line on the rudder and the outboard if it was down.
Then I used the swim ladder as a ..........
.............. tow bar. The dingy's bow line pulls right up to the tow bar and it can't drift around and run into the back of the boat or prop on the outboard.
To do this I just had to make one......
.... bar that holds the ladder up so that it sticks out horizontal to the water and I made a ..................
....bracket for the bottom of the ladder for the tow line to go through. We don't use that poly line for a tow line anymore. It is too skimpy. We use an older halyard line that we replaced. There can be quite a bit of strain on that line.
If we want the dingy out further just let the tow line out or pull the dingy up to the ladder. We have it up close for most sailing conditions and it works great.
This is a simple mod if you have a ladder like ours and now we never mess with the dingy and it doesn't mess with us. The build is here.....
http://purplesagetradingpost.com/sumner/macgregor/outside-17.html
An added bonus to this is with the swim ladder horizontal it is like a platform and much easier for Ruth to get in and out of the dingy when you pull it along side.
Want the ladder down. Pull a pin on the bar and unhook the bar and put the ladder down. To run the line through the bottom of the ladder you pull the ladder up to the stern and snap the tow line through the carabiner and then lower the ladder and re-hook it horizontal with the bar. Very simple and quick.
c ya,
Sum
Our Trips to Lake Powell, UT - Kootenay Lake, Canada - Priest Lake, ID
Our Mac Pages
Mac Links
