In the house, it's referred to as the thermostat, which in reality I suppose is simply a controller. Bear in mind that I know VERY little about refrigerant situations as a whole, but I gotta tackle mine. As it is, I have a Mermaid 16,000 btu I took out to access some thru-hulls, and I wanted to bench test it before I go to the struggles of re-installing it, and then find out it needs servicing. I think, THINK, that the difference in a home unit, and a boat unit is the home version is static, whereas the boat leans, maybe throwing off the mercury switch? I wanted to get an off the shelf cheapo to try it with, and I think it may work on the bench, but how to wire it? The ones I pick up off of the shelf says, "Unhook the old thermostat, and rewire the new one the same".
Well, that DOES sound awfully good, but completely irrelevant. For the exception of them both having four wires, the resemblance ends there.
So throw something at me here. Good info, and the usuals..
(I know, I know, A.C.'s in go fasters, but I'm spoiled).
