A.C. temperature controllers.
2,809
Ericson 29 Southport..
In the house, it's referred to as the thermostat, which in reality I suppose is simply a controller. Bear in mind that I know VERY little about refrigerant situations as a whole, but I gotta tackle mine. As it is, I have a Mermaid 16,000 btu I took out to access some thru-hulls, and I wanted to bench test it before I go to the struggles of re-installing it, and then find out it needs servicing. I think, THINK, that the difference in a home unit, and a boat unit is the home version is static, whereas the boat leans, maybe throwing off the mercury switch? I wanted to get an off the shelf cheapo to try it with, and I think it may work on the bench, but how to wire it? The ones I pick up off of the shelf says, "Unhook the old thermostat, and rewire the new one the same".
Well, that DOES sound awfully good, but completely irrelevant. For the exception of them both having four wires, the resemblance ends there.
So throw something at me here. Good info, and the usuals..
(I know, I know, A.C.'s in go fasters, but I'm spoiled).
reworb
Apr 22, 2011
234
Beneteau 311 Ft Myers Beach
If I were you I would contact the manufacturer, they are here in Florida not in some offshore location. Here is their contact info:
U.S. Toll Free: 800.330.3553
Fax: 239.418.0538
Email: info@mmair.com
2651 Park Windsor Drive
Suite 203
Fort Myers, FL 33901
By the way do you like your Mermaid unit? I'm considering replacing my failing Cruisaire unit with a Mermaid unit as I'm told they are a lot less expensive.
Nov 19, 2011
1,489
MacGregor 26S Hampton, VA
A residential thermostat, if digital is 24V but one with batteries may function at any voltage. I never tried. Mercury wouldn't work and besides they are illegal now.
I would look for a bi-metal snap acting thermostat but don't go with the cheapest on the shelf. It needs to pop open and closed quickly and smoothly. You may find a motor home thermostat would be ideal and less cost than anything marked "marine".
Oct 17, 2011
2,809
O my God! I had no idea they were illegal. I actually picked one up at the hardware store that the mercury switch was visible inside, which was my first clue about how it may not work. Probably very old stock I guess.
Hmm, good thoughts though.
And yes, the last boat I got on with a Mermaid, you could hang meat in there. Longevity? Not sure at all. The guys here on the hill like them though..
Tim R.
May 27, 2004
3,626
Your Mermaid should have 4 wires; green, black, white and red. You need to get a thermostat with heat/AC/fan control. A cheap digital Honeywell from any HW store will do. Connect the green wire to G, black wire to Y, white wire to W and the red wire to R. Make sure the R and RC on the thermostat are jumper together.
Feb 26, 2009
716
Oday 30 Anchor Yacht Club, Bristol PA
If it's reverse cycle it may have a 5th wire. O or orange that activates the reversing valve for cooling cycle. this would call for a heat pump thermostat
Mar 20, 2004
1,753
ditto on what Tim said! the digitals actually run on several AA cells, they just switch the home 24vdc power-should work fine.
Our Mermaid 16K btu unit has run flawlessly for 10 years (knock on wood!)
Tim R.
May 27, 2004
3,626
Denise, our Mermaid unit is reverse cycle but dos not have the orange wire, just the 4 mentioned above.
Oct 17, 2011
2,809
Hmm, then I am to assume that when I put batteries in the controller, and the A.C. is not wired up, the controller wires just hanging loose, that the digitals will not "light up"?
When I put the two double A's in it, I got nothing, and thought at that time my controller may be kaput. Not so maybe?
Tim R.
May 27, 2004
3,626
Bonzai
Jun 23, 2009
250
Chris-Craft SailYacht 35 St. Simon's Island, Ga.
Just replaced both cabin thermostats...recommend you stay away from the 30 day programables . I got ones that are set and forget, on and off...lol. I don't remember if the new ones required batteries but the old programables did.....maybe for memory when breakers for A/C are off?
Feb 26, 2009
716
That's interesting Tim! I'd like to look up the wiring and schematics on that. I'd never assume marine anything would be the same as land based things.
Oh then there's the 6th wire for elelctric heat.... 7th for the fault light.. It can get crazy :)
Oct 17, 2011
2,809
Yes, the thermostat is what I was referring to. I don't know why I didn't call it that in the first place. I guess maybe I was thinking thermostat like goes on the coils and senses temperatures. Anyway..
So mine must be dead. Because I put two new double
A's in it, and got nothing. Looks like Home Depot is getting a visit. The one of several things I was confused on is if there was any difference much in the "genuine marine" version, or if I could get one off the shelf.
Plan "F", or "G", something, I forget.
Not really a plan at all. More like a scheme, or a plot..
Tim R.
May 27, 2004
3,626
Chris, the original programmable thermostats that Mermaid supplied with their units were and still are LUX home thermostats with a Mermaid decal covering the LUX name. This is a little disappointing as LUX are crap. The non-marinized Honeywell units from Home Depot I use are much better and less expensive.
They also sell a thermostat which they call a "controller". Check out the page below to see what you may have.
http://www.mmair.com/marine_division/marine_thermostats
Tim R.
May 27, 2004
3,626
Oct 17, 2011
2,809
Yepper, I've got the 43103, as they call it, the "old style". While that name suits me, I'm afraid after all that the Lord has called it home. Of course I've not tried the special tool yet, hmmm..
Denise is scaring me to death with the 6 and 7 wire thing. I've only got four, I'm sure of it. And it is reverse cycle heat as well.
Thank you Tim, I've got something firm to work with now. Ignorance is tough, man. Tomorrow I'm going down to the Mary Celeste with my hatchet, whoops, I meant special tool, and see if that thermostat and I can come to terms.
Maybe I'll just stop by the hardware store instead..
Feb 26, 2009
716
Many Heat pump (rev cycle) Tstats that wall mount also have a common wire so it would be possible to burn out the power transformer. Fortunately your units don't have that. Tstats no matter how "scary" really are just switches
Oct 17, 2011
2,809
Well, at the very least, I'm getting a short education in these things. In my travels this morning, I ended up at Lowes, where I found a Hunter brand thermostat on sale for $14.95 thereabouts. That's me, this is just a bench test anyway. Four simple wires, with a relatively decent little wiring diagram of sorts. And the damn thing started up. I was really more than surprised, as this unit has been decommissioned for a while.
But it's not getting very cold. It was 85 degrees where I was standing, and my lazer thermostat shot down in the hole only hit about 65 at best. And the very bottom tubes on the condenser were frosting, which in my limited experience with A.C.'s tells me that it needs refrigerant. I'm pretty sure that the unit uses R22, which I think is everyday auto refrigerant, but the service ports are the old style, like R12 Schrader type connections.
So if I'm right here so far, my question is how do I get the R22 in the unit with this old connection? It can't be that big of a deal, huh?
Thanks so far everybody, I've slowly getting it...
Tim R.
May 27, 2004
3,626
Good job Chris. Now it is time to call Mermaid. They have a great service dept and will be very helpfull.
