8 knots
71175
I'd like to move a Catalina 30 through the water faster, under power....prop change ? Can i get the boat to go 8knots without installing a corvette engine ??
Jun 1, 2004
121
Catalina 22 PA
Absolutely, just put the boat into a river with about 3 knots current!:dance:
Catalina 380 16 Rochester NY
Hullspeed is 1.34 x sqaure root of the waterline length ...about 6.7 knots
...that plus the 3 knot river speed would get you that 9.7 knots! Mike was right!
7
71175
Looking for a serious answer to 8knot question.....three blade prop...or the new extendo prop ?
Fed up w/ personal attacks I'm done with SBO
We were serious.
In still water, unless you can somehow get your displacement hull up on a plane (you'll be the first), 8 knots is not theoretically possible. Assuming you have power in reserve to go beyond hull speed, at some point the prop simply cavitates.
Dec 11, 2008
172
Catalina 30 Solomons, MD
Well, our buddy 71175 didn't stick around too long did he?:Liar:
If it is any consolation, I saw the old analog knotmeter get pinned to 10 knots when I was a kid...we surfed down a big wave though...:dance:
How does one actually delete an account if they actually wanted to anyway?
mortyd
Dec 11, 2004
952
Catalina 30 easy living
once you achieve hull speed, not matter how much power is added all you will do is push the bow wave further ahead.
Sep 21, 2005
297
Catalina 22 Henderson Bay, NY
There is a good article in the last issue of Good Old Boat on hull speed. Tells you all you need to know in easy to understand terms.
Dale
jrowan
Mar 5, 2011
1,294
Why do people buy sailboats who want to go really fast? It's about the journey,
and I appreciate going at a rate slow enough to take things in, via the wind. Sounds like he needs to get a Grady White with a big, stinky 250 hp Mercury on the transom, gun it with a Bud in his hand, & then smack into the center channel marker at midnight goin' about 40mph. Unfortunately guys like that really do this, and a firefighter killed a schoolteacher passenger & had a dozen kids in his boat when he did it, with a blood acohol level of over .20. on the Rappohannok River. Never heard of a sailor killing his passengers like that. I hate the stab it-n-steer mentality.
Mar 19, 2011
19
Chrysler C-22 Keesler AFB Marina
So what spped do most of you all get? I'm hoping to get an average crusing speed and a fastest speed reached on both sail and motor. I am hoping to buy the catalina 30 next summer to replace my chrysler c-22 and would like to habe an idea of what to expect?
Mar 19, 2011
19
Hobie 16 was my first sailboat. It was named "Hulls Up" and I don't miss her a bit ;)
Thanks for the info. You got the 3 cycle or the 4?
Apr 5, 2010
565
Catalina 27- 1984 Grapevine
I've got the model 18, which is a 2, the model 25 is a 3. The C27 gross weight is around 7500lbs, ideally suited for the model 18. the C30 is around 10,500-12000lbs depending on how much add ons you have. You start adding AC, fridge, the extra water tank (loaded) etc. and there can be a lot of ballast on a C30 real fast, especially with a full crew. You need the extra hp, and you will never pull a skiier unless you find those cool waves under Golden Gate to ride on. But for comfort and stability it is an awesome boat. Ease of access to engine is another big plus, getting to mine stuffed back under the companionway is an exercise in spelunking.
Mar 6, 2011
25
Catalina 30 mk1 Horseshoe Bay
I have the M25-XPB with extendo prop. I thought it was 8 knots I was doing full out. That old hull speed calculation must have some variability to it or my GPS is off. At 8 knots the stern sits very low in the water.
Rob
jrowan
Mar 5, 2011
1,294
Glad to know its possible to go faster, and I know it is if you're coasting down a wave, or with a strong current pushing the hull from astern, etc. I used to have a 28 ft S 2 racer /cruiser, and she had a waterline length of only 22.5 ft. & weighed 7,500 lbs. I routinely got her to sail 7.5 knots and as high as 8.3 once. But it takes a lot of wind, good trim & some stout nerves as the rails will be deep in the water! Best I've gotten my new C 30 to is 6.2 knots, with a clean bottom, & 15 - 20 knots of wind, close hauled sailing. Cheers.
Nov 26, 2006
381
Hunter 31 1987 Fly Creek Marina Fairhope,AL.
The hull speed theory is correct, but this is thru the water speed. under sail, you could reach theses speeeds across the ground by GPS data.
3,319
Let's see......Motor sailing going with the current and surfing a 5 foot wave may let you hit that speed.
mortyd
Dec 11, 2004
952
sufing down a wave does not change your velocity through the water, it just moves the water - like a current.
