7
71175
I'd like to move a Catalina 30 through the water faster, under power....prop change ? Can i get the boat to go 8knots without installing a corvette engine ??
Absolutely, just put the boat into a river with about 3 knots current!:dance:I'd like to move a Catalina 30 through the water faster, under power....prop change ? Can i get the boat to go 8knots without installing a corvette engine ??
And measure your speed by GPS.Absolutely, just put the boat into a river with about 3 knots current!:dance:
The hull speed theory is correct, but this is thru the water speed. under sail, you could reach theses speeeds across the ground by GPS data.once you achieve hull speed, not matter how much power is added all you will do is push the bow wave further ahead.
