I have an '81 C-30 with the 5411 diesel. When I purchased the boat this Spring there was a budget water strainer mounted just inside the access hatch that faces the bow. The yard mechanics told me to change it out for safety reasons as it was not intended for marine applications and could easily break, leak and sink the boat as it is plumbed to the through hull fitting for water intake. I replaced it with a new one from Catalina Direct recommended for the C-30. I located in the same place as the the strainer I removed. The new one being larger is now being pushed against the water pump belt as I try to mount and close the access hatch. I believe if thesse boats are to have stainers they must be located some place else. No indication of where that should be based on owners manual for the 5411. In fact, they do not show any sea water strainer in the manual. Any suggestions on where and how these strainers are being mounted would be appreciated. I am about ready to just deep six the whole strainer idea all together and plumb directly from the water intake through hull fitting to the water pump as shown in the 5411 owners manual.
