Hi
I have a 2000 460 and am trying to drop the rudder (composite shaft) to inspect and clean the bearings. Unfortunately due to corrosion it is probably going to be impossible to remove the quadrant arm without causing damage to it, rather than the fibre glass of the rudder stock. (Whose idea was it to use stainless bolts in aluminium with no corrosion protection!!!)
If I do have to destroy it in removal does anyone know of a supplier for a new one.
Also if I decide to replace the rudder with a new Foss Foam one does anyone know what is involved and the best suppliers for replacing the bearings which presumably will be totally different form those on the composite shaft.
One other observation. There is a white spacer at the top of the rudder tube that seems to support the quadrant and presumably the weight of the rudder. This does not seem to have been cut square and the eight therefore only bears on one side of it - is this normal?
I have tried the search engine but maybe its me I didn't get much joy.
Regards
Jim Golt
Moondance
Regards
Jim Golt
Moondance
