4" wide stripe down by waterline
Tom
The 4" wide vinal stripe down by the water line is all faded. Can you paint over it or does it have to be removed ?.
Ross
Jun 15, 2004
14,693
I paint mine. Use high grade industrial machinery enamal
with a package of fungicide mixed in, mask the stripe, scuff it with 80 grit sand paper and wipe the dust and paint. All done.
Jun 1, 2005
772
Pearson 303 Robinhood, ME
I can't imagine...
paint sticking to that. However if it is all faded... maybe there is something to stick to? If I was to paint it... I would mask off, and lap 1/8" onto the vinyl both top and bottom and have at it. Paint with what... would be my question. If you are going to go thru the trouble of doing all that... I would call one of those mobile sign guys to come out to the boat... and give you a new vinyl stripe! Call around... the price will vary greatly.
Tim R.
May 27, 2004
3,626
Really Ross?
I don't see how the paint would adhere to this. Tom, take the time to do it right and remove the vinyl first. Use a heat gun on low and you should be able to slowly peel it up. You will then need to remove the glue using 3M adhesive remover or similar. You could buy another roll of the vinyl and apply it but boot stripes usually are not a uniform width because of the way the hull changes shape from end to end. It just doesn't look right if not done correctly.
Ross
Jun 15, 2004
14,693
Paint sticks like a brother to most vinyl.
Scuffed with a bit of sand paper and if it doesn't work you can still peel the vinyl off later.
May 24, 2004
7,228
CC 30 South Florida
If you want to turn a one day job into a week
long ordeal you may consider removing the stripes.
Jun 4, 2004
844
Hunter 28.5 Tolchester, MD
Vinyl, Really?
Tom Assuming yours is a Hunter; (since you aren't registered & thus the boat isn't indicated) Most Hunters have the boot stripe roal blue color built into the gel coat. It typically isn't vinyl or paint, but either could have been used by a previous owner to overlay as a new boot stripe. The cove stripes under the rub rail were typically vinyl tapes. You can use automotive compound and see if it refreshes the color of a gel coat boot stripe, then wax it to restore the shine. If vinyl was added overtop of gelcoat, it's easy enough to scrape off with a heat gun or even with just a 4" wide wall paper knife. I wouldn't paint over vinyl as a noncompatible solvent could create an interesting mess. West Marine makes a vinyl tape in numerous colors and widths. I've used 4" Captain's Navy and 2" Metalic Silver to replace and re-create the cove and cabintop stripes. I'd be a little cautious to use vinyl as a boot stripe as it is a little more prone to damage in that location when scrubbing the waterline.
higgs
Aug 24, 2005
3,738
Nassau 34 Olcott, NY
My 2 cents
I would not paint over vinyl. i think the proper way to deal with this is to remove the vinyl tape and either retape or paint on a water line.
1,438
Oday 25 pittsburgh
Like Ross siad, it will bond with mild sanding.
The life span of the paint is the question. If you want to dress up the boat fast, sand and paint. If you are going to own the boat more than two years, remove the vinyl. Most vinyl lettering is time dated. e.g. 2 year, 5 year, 10 year. That is for the color in the lettering.Who knows how long the bond will last in UV conditions. So, your north/south location plays into the UV factor. Your future intensions for owning the boat also plays a part. Short term, sand and paint. Long term, remove prep and paint or maybe another vinyl stripe. r.w.landau
Jun 7, 2007
515
Hunter 320 Williamsburg
I'm with Sauer
Compounding does wonders to revive the stripes on Hunters. Try it first as less time-consuming, less expensive, and highly productive.
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
paint will stick
As a sign guy myself I can assure you that if prepped well (get ANY & ALL wax off and perhaps a light scuff with a scotchbright) the paint will stick. We use all types of vinyl as a base color and spray additional colors on top to create fades and other effects. These are used regularly on vehicles and boats.
tcbro
Jun 3, 2004
375
Hunter 33.5 Middle River, MD
If it's really vinyl.....
... go to an auto body shop supply house and get a "pinstripe eraser". It fits in the chuck of your drill and removes stripes easily. If it's gelcoat, buff it out using ever finer grades of compound/polish then wax it. If you want to paint a new one on use Interlux "Brightsides" single part polyurethane paint.
Jun 1, 2005
772
Before you try...
with the buffing... you might want to hit it first with some very fine wet/dry sandpaper (2000 grit?) and water... if the stripe is in the gel-coat.
