PO had cut the heat exchanger hoses and tapped off the engine outlet / inlet ports. Probably leak or blockage in the heat exchanger.
Because of leaks I am changing the heat exchanger.
Plan to go all the way and reconnect the heat exchanger.
Problem: Calls to Yanmar agents all respond with "What is the part number?"
Well, no online source, that I have found, has a detailed diagram of the part and the part number.
If I had a part number, I could order every part that Yanmar has ever made but without one I am stuck.
Has anyone got an idea of the part number.
Could they just be a standard industrial fittings that were just tapped into the cooling water manifold?
Any help would be appreciated.
Thanks
Thanks
