Brian
Has anybody else had problems with the base of the mast deteriorating and how did you fix it? I have had 2 suggestions as to how I can fix the problem. The first one would be to cut off the bottom 2 inches of the mast and then build up the surface under the step by 2 inches using fiberglass and a steal or aluminum plate. The other would be to cut off 2 inches and place a "spacer" where the current step is. Does anybody have any suggestions?
