37C Jib sheets caught on vents
Apr 19, 2020
8
Hunter 37C 143 Cleveland
I currently have my 37c sloop rigged with a 140. Sometimes when tacking my sheets get caught on the vents. Has anyone encountered this and have a solution? Thanks.
Catalina 34 Casco Bay
I have adjustable Genoa blocks on cars.. Just before tacking I'll run the cars forward. This prevents the sheets from flogging the isinglass and wrapping on the dorades..
  • Helpful
Likes: sail sfbay
I think the release has a lot to do with it. Try a later release - like when the 140 has filled on the new windward side. That should cause the jib to snap through the foretriangle with less tendency to cause mischief.
Likes: jon hansen
C&C Frigate 36 St. Margarets Bay, Nova Scotia
Later model H37C (1982-83 on) had a stainless steel 'crash' bar spanning over the dorade vents. I never hooked one with a sheet on my old boat.
Likes: Mikem
Apr 19, 2020
8
keeping the slack out of the sheet has definitely been helping, definitely helps to have enough crew too.
Unfortunately not an easy option on this boat.
I think doing this has helped a little as well.
I saw a picture of what you mean, definitely looks like the best solution.
May 31, 2007
783
Hunter 37 cutter Blind River
I have had that issue. Since losing one overboard, I now have a short tether screwed in to the vent and the other end into the dorade box. Of course since doing this I have not had a snag. Seems to work but the original theory was that the vent could be pulled out but not lost forever.
