35.5 Legend Fuel Tank Issues
19
Catalina Capri 18 Lake Whatcomb
Hello Fellow Hunter Owners,
I have owned our 1994 35.5 legend for four years and really like the boat for many reasons. I have made some of the suggested modifications from the forums as well and really appreciated the help. So here is the one area that I has frustrated me over and over and I hope I can help others as well as myself in exploring the solutions. I have the 3gmf power and a racor filter system. For the past three years I've fought clogged filters, stalled engines and several ruined trips due to fuel issues. So far I've increased filter size to T20 and micron level (2-10) per racor, tank cleaned with side access plate installed, fuel polished, tank cleaned again, use algecide, keep the fuel full, buy it at a high volume dealer, etc. Last week I was towed into Avalon again with the same problem. The local mechanic really knew his stuff and felt the culprit was the pick up tube and fittings. He used compressed air to blow out the clogged fuel line from the tank and that got us going. He suggested cutting an access hole in the swim platform right above the pick up tube location so it could be modified/ serviced. I'd like help with pick up tube modification ideas/ procedures, tips, etc. My First inclination is replace the tube, add new elbows, fuel lines, and possibly an electric fuel pump, possibly even and in tank pump, do all the cleaning and start again. I've now heard some folks have shortened the pick up tube as well. So I need input, help, advice. Waiting to here from you all to finally solve this one.
Gersailor
Dec 2, 1999
15,184
Gersailor:
I would suggest that you end your problems with a new poly tank. You will be better off doing this and ending your frustration. While this may not be the quickest, easiest and cheapest method it will probably pay off in the long run.
I had a minor problem a few years ago and decided to put in a dual filter system. I can now switch between one of two filters in a matter of moments.
http://forums.hunter.sailboatowners.com/showthread.php?p=701862&highlight=filter dion
May 30, 2005
19
Thanks Steve, I certainly will consider your advice, The current tank is a poly tank but I would have to cut it out to remove it and probably have to have a custom tank built. It would certainly be a lot of trouble. Thanks for the input.
Rick D
Jun 14, 2008
7,207
Certainly, a dual filter arrangement as Steve has would seem to be a big help. However, if the experience in Avalon is indicative, perhaps there is a screen on the bottom of the pick up tube? Did you inspect it? If so, perhaps the answer is to remove it. Waaaay back in my head I seem to recall it being a problem on several Hunters.
May 30, 2005
19
Thanks Rick, I also read about the screen problem. My tank does not have a screen, as a matter of fact I ran into a couple who had a 37.5 who removed the screen and shortened the pick up tube and solved their problem but they could access the tube to clean it but my tank is under the swim step. Thanks, Ger
May 30, 2005
19
It looks like a new tank is in order. Any advice on how to approach this? Has anyone replaced the tank on 94 35.5 legend or similar boat who could suggest the steps and considerations that might help with this process ? Gersailor
kamper
Aug 7, 2010
7
Hunter Legend 45 Oceanside, CA
Hey Gersailor, we're in O'side too and having very similar problems with our Legend 45 with pulsating rpms.
Had fuel polished and new lines back to engine, plus new filters. It ran good but right before Avalon had pitching seas/strong head winds and it starting pulsating again. The p/u tube is hard to get at on mine and I'm leaning towards replacing it or pulling the screen (if it has one). So far its stumped my mechanic and its starting to be a money drain. Ouch
Kamper
May 30, 2005
19
Hi Kamper, That sounds very familar. I just removed my pu tube today, it had a screen and it was gunky. My tank is impossible to work on, so tomm. I intend to cut the tank out so i can replace it. I am researching using a portable tank. I'm on I dock. come by for more info. Gersailor
May 30, 2005
19
Hello Hunter Legend and other boats using Moeller Tanks. There is a screen (even though I was assured there was not one by the fuel polisher expert) in the top of the pick up tube. I discovered this after cutting the tank out of the aft storage lockers. At this point I would recommend that anyone having fuel issues check out this factor. I'm now working on a modular portable tank system using 6.5 gallon tanks that can be added as needed. More later.
Gersailor
kamper
Aug 7, 2010
7
Screen access?
Because the screen is at the top of the tube do you think its possible to get to it and remove it without pulling up or taking out the entire length of tube? Is the tube removeable or welding in?
thanks,
Kamper
