Hello Fellow Hunter Owners,
I have owned our 1994 35.5 legend for four years and really like the boat for many reasons. I have made some of the suggested modifications from the forums as well and really appreciated the help. So here is the one area that I has frustrated me over and over and I hope I can help others as well as myself in exploring the solutions. I have the 3gmf power and a racor filter system. For the past three years I've fought clogged filters, stalled engines and several ruined trips due to fuel issues. So far I've increased filter size to T20 and micron level (2-10) per racor, tank cleaned with side access plate installed, fuel polished, tank cleaned again, use algecide, keep the fuel full, buy it at a high volume dealer, etc. Last week I was towed into Avalon again with the same problem. The local mechanic really knew his stuff and felt the culprit was the pick up tube and fittings. He used compressed air to blow out the clogged fuel line from the tank and that got us going. He suggested cutting an access hole in the swim platform right above the pick up tube location so it could be modified/ serviced. I'd like help with pick up tube modification ideas/ procedures, tips, etc. My First inclination is replace the tube, add new elbows, fuel lines, and possibly an electric fuel pump, possibly even and in tank pump, do all the cleaning and start again. I've now heard some folks have shortened the pick up tube as well. So I need input, help, advice. Waiting to here from you all to finally solve this one.
Gersailor
Gersailor
