I have a 2gm20f circa 1985. In the manual it says to use Shell Rotella 20 wt for temps between 50-70 degrees. Problem is I can't find Shell Rotella 20w anywhere. I have been using the rotella 30wt but now that the temps are dropping id like to be using the right oil. I haven't been able to find any straight 20 wt oil for that matter. Most have moved to multi wt synthetics.
what oil should I use on my older yanmar 2gm20f? Is there an updated manual that shows new oils to use that are better? 25 yo manual probably isn't current
Thanks,
Jared
Thanks,
Jared
