2gm20f factory oil rec. not found anymore
456
Hunter 31 Seattle
I have a 2gm20f circa 1985. In the manual it says to use Shell Rotella 20 wt for temps between 50-70 degrees. Problem is I can't find Shell Rotella 20w anywhere. I have been using the rotella 30wt but now that the temps are dropping id like to be using the right oil. I haven't been able to find any straight 20 wt oil for that matter. Most have moved to multi wt synthetics.
what oil should I use on my older yanmar 2gm20f? Is there an updated manual that shows new oils to use that are better? 25 yo manual probably isn't current
Thanks,
Jared
Joe
Jun 1, 2004
8,321
Have you tried calling your local Yanmar marine service center? They should be happy to give you that updated information.
Dec 2, 1999
15,184
They have been recommending multi weight oil for years. Contact the distributor and ask them.
I never saw Rotella recommended only Yanmar oil.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
15-40
I have been using Rotella 15-40 since the boat was new 2007 and I think that is what most are using.
nick
Nov 6, 2006
10,216
Jared, the original Yanmar engine shop manual recommends Mobil Delvac 20-40 for your engine. The newer oils are 15-40 and Delvac is available at Wal Mart .. Shell Rotella T 15-40 is equivalent diesel engine lube oil and is used a lot by Yanmar engine owners. Probably not a good idea to use a synthetic..
Dec 14, 2003
1,450
Ditto for the Shell Rotella T 15W-40 1 on my 3GM30F. Also available at Walmart.
Sep 6, 2011
82
Oday 322 Hawkestone YC Lake Simcoe
I run the Rotela 15/40 on my Yanmar and aslo on an old MGB 4 banger. It is a good oil for hard working little engines...
May 24, 2004
7,213
CC 30 South Florida
I know somebody who is hoarding a cache of Rotella 20 weight. Strictly under the table stuff but guaranteed 1983 vintage. Pardon the pun, no harm intended but the oils have progressed immensely in the past 30 years. Like others have recommended a good 15W-40 will outperform the vintage Rotella at any temperature. Manufacturers update their recommendations from time to time and its is prudent for us to keep current.
Jan 30, 2012
1,154
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
Jared
As Klodie says in #5 above avoid the synthetic. Suggest Rotella T 15W40 in the Yanmar 2GM20F and any earlier series motor.
Use your straight 30 in your transmission.
Charles
May 24, 2004
7,213
CC 30 South Florida
The reality is that regular oils and synthetic oils both offer the same engine protection. In a combustion engine both oils get contaminated with combustion by-products, intake dirt, and unburned fuel at the same rate. We tend to change our oil at preset intervals so why pay considerably more for the same protection. Now you use synthetic oil in a clean enclosed space like a transmission with few contaminants and it will last a lifetime. Another factor is that some with older engines and transmissions have reported a larger incidence of oil leaks as perhaps the old gaskets and seals do not work that well with the synthetic oils. Your boat, your choice. My personal choice, regular oil changed every six months.
