2GM20F Engine overheating
Apr 26, 2015
22
Hunter 28.5 Lake Quachita
I have a Hunter 28.5 with a 2GM20F Yanmar engine. I can't seem to solve my overheating problem with the quick fixes, so I am bowing to the forum gods for help.
I have replaced sea water impeller, which was damaged and needed it, and I have made sure that fresh water is full. I have cleaned out water intake port, best possible being in water. Water inflow seems low to me, but when I remove hose and open sea-cock, water shoots up about 4", is this enough? All I have succeeded in doing is make consistent overheating alarm after 10 min at medium idle (1000 RPM). With my limited experience and the text manual, I think of thermostat bad? Heat exchanger need cleaning? Heat sensor unit bad? ??????? I nee help and would appreciate all comments.
Jun 6, 2006
6,990
The heat exchanger has no moving parts, the thermo does. I'd start with the thermo, test it in a pot of water on the stove with meat thermo. Should start to open at the temp stamped on the thermostat. Should be full open about 10-15 degrees hotter. Also check to see that it closes at the right (same as opening) temp as the water cools.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
you may need to pull the end of the heat exchanger and remove some rubber from where the impeller was damaged on your water pump but first take the water hose going from the raw water pump off and see if it has a clog in it if not then on to the heat exchanger
Dec 2, 1999
15,184
I am with the Woodster on cleaning out the heat exchanger. If you had a damaged impeller there is a good chance that some of those parts in stuck in the tubes.
Apr 22, 2011
870
Hunter 27 Pecan Grove, Oriental, NC
Do you have a good amount of water spitting out of the exhaust?
Rick
Oct 5, 2004
1,095
Hunter 420 Passage San Diego
Before you get out your tool kit, take a trip to harbor freight tools and buy yourself a thermal reading gun with the little "lazer" on it! Get ready to save yourself some time. I love them because when I making my rounds motoring, I can use the gun to tell me a bunch about my trusty "iron genny". Have some fun learning how to use it, lol, most belly buttons chime in at about 88 degrees!
The obvious, do you have water flow out your exhaust? That will tell you everything about the flow of water from that seacock you mentioned, through your raw water loop, and then overboard. If it is flowing, your not totally clogged BUT it may not be enough. That is critical.
You have an antifreeze loop. Good. How many hours on your engine? Probably in the 1000 hour range depending on your waters, it is time for an acid dip. However, that is a pain in the ass job.
So maybe a few IMHO ideas before you do the afore mentioned. You mentioned a nice stream at the seacock. Well where that tube next plugs should be your raw water strainer. Loosen the wingnuts and pull it out. Clean? Yes move on, no... clean it out and start her up. Bring her up to temperature and get out your gun. Or as you said bout five minutes or so. The seawater from your strainer to your raw water pump and up into the exchanger is not going to see big changes. Your antifreeze temp at several places is gonna tell you a bunch.
So in no particular order you need to check your thermo as mentioned. Shoot it with your gun, shoot the hose on both sides of it. It should be a 160 degree thermo so it should be pretty close when you shoot it. The coolant on either side of it should show some difference in temps. The hot side will be what just circulated through the engine and the cool side what just went through the exchanger.
Now find your way back to your mixing elbow. Its on the back of the engine. Its the exhaust pipe. So the hot exhaust is mixed with seawater in the mixing elbow to cool it so you dont melt your exhaust hose. Shoot it on both sides where the little water line from your exchanger screws into it. I forget the temp range but it should be a significant difference on either side. What happens over time to a mixing elbow is it basically gets heart disease and your seawater will not flow through it. But it being clogged is a different show.
This should give you an idea of where to start. IMHO, thermostats are to simple to fail and a pain to take out and test, but that is not to discount the expertise of ANY of the above posters. Some are better with tools than others.
So to sum up. Raw water seacock, raw water strainer, impeller, through exchanger housing, mixing elbow, water in exhaust.
Antifreeze loop. Temperature out of exchanger to engine , through engine and back to thermo.
Edit: Do you have a hot water heater that works from running your engine. Yep that is in the antifreeze circuit.
Damn I wish I had my engine to look at. Hopefully some of the guys will help make this easier to digest.
Cheers and good luck
Apr 26, 2015
22
Thanks, I will check the heat exchanger for debris. When I was changing the impeller, I forgot to close the sea-cock, and I experienced steady flow, so line is not blocked.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
check the line going from the pump to the heat exchanger also
Rick
Oct 5, 2004
1,095
Read my post above.
Certainly not expert.
Just trying to save you from a fit. I just believe in a "more than one step post"
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Cleaning your heat exchanger
I fouind on my 2GM20F that a 22 caliber gun cleaning rod with a bore brush fit perfectly. I didn't even remove it from the engine, just removed both caps and cleaned it out. It was a snap once I finally got everything apart.
Ken
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Ken
yes it does
7
Hunter 31 Port Jefferson, NY
I had the same problem as you. I did all of the above but the last thing I did was remove the 90 degree fitting to the Mixxing Elbow. It was cloged. I cleaned it out and it is fine. It's been good now for the last 2 years. Good luck.
B.T.O.
Kh3412
Oct 11, 2012
56
Catalina 34 Lake Erie
I found that when fixing things it is always the last thing I check that is the problem. So I try to work backward but, the problems are smarter then me and always switch around so it is the last thing again. Maybe if I work with the lights off they won't know.....
Oct 29, 2005
2,358
I know how it is. Been there. So to avoid it being last thing you do that fix it, why not after that repair, go fix something that isn't broken then that broken fix isn't last anymore. :D Am I smart or am I....;)
Oct 24, 2010
2,405
I like it!
Ken
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
well now that goes against the man law ...if it ain't broke don't fix it...it also cut in to the beer time:eek:
Sep 12, 2011
88
Hunter 27 Annapolis
Nice write up
Jul 28, 2013
126
Hunter 34 Holland, Mi
If you pull the end covers off of the heat exchanger take it to a radiator shop and have it cleaned. If your going through the work make sure it's clean before buying new gaskets.
