I have a 2GM that won't run below 1100 RPMs. I have cleaned out the mixing elbow and changed all the fuel filters. What else could cause a problem like this?Hawaii Dan Illusions
try disconnecting the throttle cable at the engine and see if you can manually reduce the rpm's by moving the linkage. May just be a cable travel adjustment. Good luck
