Does anyone know the weight limit on the motor mount? It's the factory fiberglass and 2x6 pine mount. I removed it to fix some rot on the plywood bits. Debating on replacing it with a heavy duty Panther mount. The backing board was dry rotted 3/8 plywood. Obviously that will get replaced.
By my understanding, these boats c came with 2 stroke 8hp tohatsu that weighed about 75lbs. I am hoping n to upgrade to a 9.9 4stroke long shaft, electric start, with remotes. It weighs about 117lbs.
Other than upgrade the backing board, what would you recommend? Is it adequate?
My plan is 3/4 plywood bedded on epoxy and 1708 as far as I can go, then another layer or two of 1708 on top of that. Panther mount im looking at is rated for 235lbs.
