27-2 motor mount
Aug 10, 2020
613
Catalina, Hunter C25 3559 Rocky Mount
Does anyone know the weight limit on the motor mount? It's the factory fiberglass and 2x6 pine mount. I removed it to fix some rot on the plywood bits. Debating on replacing it with a heavy duty Panther mount. The backing board was dry rotted 3/8 plywood. Obviously that will get replaced.
By my understanding, these boats c came with 2 stroke 8hp tohatsu that weighed about 75lbs. I am hoping n to upgrade to a 9.9 4stroke long shaft, electric start, with remotes. It weighs about 117lbs.
Other than upgrade the backing board, what would you recommend? Is it adequate?
My plan is 3/4 plywood bedded on epoxy and 1708 as far as I can go, then another layer or two of 1708 on top of that. Panther mount im looking at is rated for 235lbs.
Mar 6, 2008
1,532
Here is a photo of the mount. No plywood.
Unfortunately I do not have the manufacturer name, but I remember that it could lift 175 lb.
This was on my 1084 Hunter 25.5, I no longer have this sailboat.
The Panther also has a tough plastic base and can lift 132 lb according to its specs. The only spec I could not find is how many inches does it lift, will it be completely out of the water. You also have to tilt it forward which helps to bring out of the water.
Likes: SailingLoto
Aug 10, 2020
613
Thank you. That's very similar to the Panther I was looking at. It looks very robust.
Sep 24, 2018
4,817
Catalina 30 MKIII Chicago
One issue that I ran into on my last boat was that the powerhead would hit the transom when I tried to tilt it (even with the mount down!). Check these dims to avoid this issue
Jul 28, 2017
3
Hunter 27 Lake Martin, AL
I have a 4 cycle Honda 8hp on my 27-2...
Top speed of 7-8 knots...Weighs about 100lbs...
Tilt works fine...
An extension, attached to the transom on the port side with 4 bolts by the previous owner or the factory, is what the motor rests on...
But I do not know if there is some type of backing plate inside the transom to reinforce the fiberglass, because as far as I can tell, there is no inside access to that part of the boat...I've always wondered just how this was done...I would think that some extra reinforcement would definitely be needed...
The remote control unit is attached to the small, vertical wall right across from the tiller post, right beside the hinge of the rear port-side seat lid...And unfortunately, the tiller does hit against the remote unit when pushed to port...And the lid to the fuel tank compartment also hits against the remote unit, limiting it's movement...
I could send some pics if you prefer...
I sail on an inland lake & the 4 bolts are still tight in 7yrs of ownership...
Maybe another owner could elaborate further on just how the extension is attached...
And sorry if I gave you more info than you may have needed...
That was a good write-up.
I think it is reasonable to try and understand how the attached mount was done. Without access to the inside (perhaps a remote camera could shed light), you are left to inspect the outside transom. Look for cracking of the gelcoat where the mount connects to the transom.
7 years of use and nothing showing wear is pretty good.
Looking for more of your sailing experiences.
More information is generally better than less. Too often the first responses to a post are along the lines of "could you tell us more" or "we really need photos"
If the remote controls are the single handle kind, then once the engine stopped, just push the handle forward so the tiller clears.
Is there a place to install an inspection port so the motor mount can be inspected?
One last thing, your question is similar to the OP's question, but different enough to warrant its own thread. Threads have a way of drifting off topic which can get confusing for readers, best to keep questions separate.
