That's one of the first things I noticed. It's good for spilt drinks or a bucket of water, but if actual waves were hitting the cockpit, you would be on big trouble.I've always thought the drain in the cockpit of my 26S was too small. I've considered more than once how I could improve it.
Whoa, 4" is huge compared to the minuscule 1-3/8" we have now.Oh, yeah, the drains are too small for offshore. 4" or 2, 3" would be right, but where would you cut to let them out?
(on a 25 would be easier)
Well normally people don't take these boats off shore or where those kinds of waves are likely. I probably won't either, but a bigger drain would have been nice. I don't think 3 or 4 inches would have been too big.Well, I was thinking it may be possible with a hole saw cut out a much larger hole, and install a drain fitting. Of course a matching larger thru hull would be required too. I don't know maybe not necessary. These boats have been around a long time, haven't heard about bad things happening because of the drain. Just seems so small!
I have recently installed these rolled up lengths of 15mm galvanised chicken wire and they seem to be working well - just excuse the dirty boat - has been sitting in the back yard for way too long!! - but hopefully will be back on the water in another couple of weeks.I went to my boat today in the rain to get my fridge owners manual, and found about 5" of water in the cockpit.
I knew there were some leaves and stuff in there but I didn't think it was that bad.
Does anyone cover the hole with anything?
My perception of a through hull fitting, is just that it goes through something. I wouldn't just assume it's position relative to the waterline.Seriously, why would you ever use a thru hull (presuming you meant below the water line)?
Race boat sail with open sterns...
Did I misunderstand you, and you just meant the fitting?
Jeff
No, I didn't mean below the water line. A thru-hull fitting certainly can be installed in the side of the hull above the water line. An example is a drain for a sink. Macgregor simply glassed in a piece of PVC for the cockpit drain and the sink drain, both above the water line. What I was implying was to remove the PVC drain hole for the cockpit, and install a larger thru-hull fitting. The biggest I've found though is 2", what we have now is 1-3/8".Seriously, why would you ever use a thru hull (presuming you meant below the water line)?
Jeff
Yeah, the problem with the Mac 26C's is that there's a large lazarrette between the cockpit well and the transom. Can't just install scuppers straight out the transom. We need to install some plumbing inside the laz, and at the same time not get in the way of valuable storage space.Doehunter,
One of the benefits of not having like-boated-sailors on the Forums (Morgan owners gets like 2 posts per year) is I get to stalk all the rest of you guys!
Sometime back I read over on Catalina 22's about a scupper improvement for those boats that allows the cockpit to drain directly through the transome. Might help with your draining problem.
You could probably do something like this http://catalinadirect.com/index.cfm?fuseaction=product.display&product_ID=536
for less money.
That probably would be better, less clutter under there too! For sure I don't need that trap, just did it that way to get the right angle to make connection.Would it not be more efficient to run a separate drain line straight out the stern for the motor well and dedicate the side exit to the cockpit drain? No dips in the routing. Seem like less likely to plug up with dirt, debris or ice. That's my plan anyway.
