23 oday rigging instructions
4
oday 19 ri
Hello I am new to sailing and just purchased a 1980 23 oday. Does anyone have a copy of the rigging instructions?
May 31, 2004
858
Catalina 28 Branford
Mike: here is everything you ever wanted to know and probably all that Oday ever printed for your boat. Enjoy and welcome to the club!
btw, I've tried to upload this file to this website a number of times, and it never seems to work.
Note that because of the size of the file as a whole, I am splitting it up into several parts.
Mike
858
You probably want the other side of the "manual". Yes, the manual is a two-sided single sheet of paper. Simpler times...
I think this file is already uploaded to this site and is available in the Boat Info section.
4
oday 19 ri
Guys
Great response and material, much appreciated! Let me review and look at the boat, but i am sure that I will have other questions!!
Thanks!
Mar 9, 2013
4
oday 19 ri
All
I just picked up a 2012 nissan 9.8 motor with 3 hrs on it for 1500. With that said is there a way to "lock" the engine while it is on the boat so no one steals it? The boat will be sitting on a moring and i dont want someone to steel it
Thoughts ?
Mike
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Plenty of outboard locks available, from simple cables and padlocks, to crazy bars that cover the clamp handles. You'll find plenty if you google outboard lock. The trick is finding one that fits with your outboard mount bracket. On a 23, you probably have a lifting Garelick type, which ought to allow any width bar style. They don't often fit on smaller fixed position brackets where the clamp screws are down between the side pieces of the mount bracket.
Brian
May 31, 2004
858
Master Locks sells an outboard lock package that includes a brass padlock and one of those u-channel bars that slide across the thumbscrews that fasten the outboard to the outboard mount. I bought one and put it on at the beginning of the summer. At the end of the season, the lock wouldn't open: corroded. I figured I just got a bad apple and bought another package the next year. This time, I rinsed the lock in fresh water after every sail. At the end of the year, same result: the lock was so corroded I had to cut it off. Never again. I now use a kryptonite cable bike lock. No problems after 5 years.
1,957
Oday Day Sailer Wareham, MA
I have used a simple padlock through both clamp screw handles for years on our assortment of outboards. On our 14' powerboat I originally locked the 9.9 on using a Master-Lock brand outboard lock that was a channel over the clamp-screws held on by a padlock at the end...... the padlock corroded and I broke the key trying to open it......OK, no problem....I just took a pair of vise-grips and simple twisted off the little tab that closed off other end of the channel! So much for great security! Since then I've used a little waterproof grease or lithium grease on the padlocks and that usually keeps them free. One tip, point the key-hole down to prevent water from getting in, or tape over the key-hole if you install padlock with key-hole up.
