2018 Mahalo Cruise
Stunningly beautiful. Thanks for graciously bringing us along.
- Will (Dragonfly)
Looking Good in your Neighborhood. @LeslieTroyer . Great sight...
Red sky at night Sailors delight.
What about that red sky at night saying? No delight?
Now I'm on tenterhooks.
- Will (Dragonfly)
May 20, 2016
3,015
Leaving Hope Island and hitting the pass was problem free. After that was another story. For some reason the dinghy flipped vertical after Deception. After that I looked for a calm place to set it right - no luck. I did get it in the water and towed ok. Started sailing until winds got >25kts. I figured this was my solo limits and wound in the job and continued motoring. Hit a rip off south east side of Lopez Island that ticked my but a bit. The took a scheduled break at McKay Hbr to make sure there was sufficient water for me to enter Fisherman’s Bay. This was a mistake. While I was napping in a sheltered Hbr the wind and waves continued to build. When I left it was horrible most of the way up to Fisherman’s Bay. I buried the nose too many times to count - even up to the mast. Coming into Fisherman’s I usually run 1-2 kts. Today it was like 4-6 so I could ensure turns into the wind ( which died down to ~27kts).
I’m now safely anchored with out hitting any more crab traps. Wind is sill howling and should be 40+ overnite.
I think I will self medicate till I fall asleep.
Makes you want to review heavy wind cruising. Shows the importance of knowing where you can duck into to catch your breath. And know how to handle your boat when the wind is against you or trying to knock you about. Way to go Les.
Jan 30, 2012
1,150
Nor'Sea 27 "Kiwanda" Portland/ Anacortes
Blowing solid at Anacortes Marina too. Ferry skipper says 35 + probable. I think more Westerly and down late.
Charles
Jan 5, 2017
2,464
It was blowing here earlier (Port Hardy) but seems to be dying down now. At least all those clouds seem to be leaving. Sunshine tomorrow?
May 20, 2016
3,015
It was sustained 30 kts gusting to high 30’s going up San Juan pass between Cattle pt an Lopez. Then sustains 25 gusts to 30 goin north to Fisherman’s Bay. Sounds like 20 with gusts to 25 right now in the bay. As often as you pray for wind on a cruise I think this is a bit over the top. Not scheduled to get Dow to 10 until 8am tomorrow. So long night tonight
Les
May 20, 2016
3,015
I think we are skipping Jones and going to spend 2 nites in Wescot. One of the 3 other Everett boats is going to Friday Harbor , the other two convinced me to join them in Wescott.
Hope to see you in Bedwell.
