2004 Hunter 36 Interior Locker Deck
bris59
Jul 5, 2019
8
Hunter 36 Houston
Anyone know where you can get deck for there interior lockers? My very specific case is the air conditioner which had cutouts for the mounts. I am thinking of changing from Domestic to Webasto so the footprint is different and I will need a new piece of decking in that locker to properly mount.
Decking? A pic would help. But if you are talking about a base to set the AC on, a piece of starboard or other type of PVC board would be a good choice.
Jun 25, 2004
606
Hunter 306 Pasadena MD
Along the same lines: I think this isn't a question of using the exact thing that was there when the boat was new. You're talking about something mounted inside the lockers, so you need to use whatever makes sense (plywood, plywood sealed with epoxy, starboard...), depending on how likely it is to get wet, what kind of weight it has to withstand, etc. There is no perfect answer: just do what makes sense from an engineering standpoint.
  • Helpful
-na -NA Anywhere USA
Go to the Hunterowners.com. Ask that question there. There is a help desk and the person you would be talking to is a former Hunter employee who knows that boat
