2004 Hunter 33 - Need a windlass fix or replacement
May 23, 2022
2
Hunter 33 Vancouver
The original windlass is no longer available. Is there anyones here who have a suggestion of a replacement model that fits?
Jan 4, 2006
7,787
Not familiar with Simpson Lawerence windlasses but several of their models seem to be a fit to your current install. Unable to determine if the dimnsions will fit your set up. You will not be able to easily change the make of the windlass to another mfg. due to the locker layout.
Have you checked out your current windlass to determine what the problem is ?
Jan 4, 2006
7,787
Another quick note here. I'm was actively involved in open warfare with our parrot and cannot think, type, and see what this guy wants, all at once. He's now wandered off.
See if there is a model number on the windlass or maybe a manual that came with it. If there's a model, the dimensions can be compared to a current SL model.
That's after you've determined what the problem is with the current windlass.
Sep 20, 2006
2,953
I installed the Lewmar VX2 couple years back.
