I am trying to replace existing sanitation hoses which are permeated and smell bad. I cannot seem to remove the hose that runs from the head to the holding tank, it is disconnected at both ends.
I have cut all the plastic clamps that I can find via access holes. The clamps are tie wrap type that are screwed to the aft berth sub-structure that is bonded to the hull. From the locations of the clamps, it would seem Hunter attached the hose and clamps to the aft berth sub-structure before bonding to the hull.
Has anyone changed their hose, and how did they remove it?
Mine seems held somewhere, do I have to cut an access hole?
Help!
Help!
