2001 HUNTER 320
May 5, 2022
5
Pearson 27 West Sayville
LOOKING FOR SOME INFO PLEASE...
About to purchase a hydraulic autopilot made by Raymor. Does anyone have any positive or negative information that would be helpful to me.Does anyone have one on a Hunter 320, is it compatible? Thanks.
We could use some more information.
Are you buying just the drive unit? or the whole system including the sensors and computer?
Am I correct in assuming that autocorrect got you and Raymor, is really RayMarine?
Jan 7, 2011
6,014
Oday 322 East Chicago, IN
You need to figure out a strong point to mount the drive. There is also a pump and hydraulic hoses that will need to be run. And you need a tiller arm on the shaft to connect the drive to. Seems a bit of overkill on a 32’ boat.
A linear drive (electric) does a similar job, but eliminates the pump and hydraulic hoses.You still need a strong point to mount the drive and the tiller arm on the shaft.
Greg
