Hi, I just got a 2000 Hunter 240 and have been going through it replacing the worn out parts. I just replaced the forestay furler extrusion and the jib halyard is still wrapping around the sail. I know this isn't supposed to happen. I don't know if the sails that came with the boat are correct.
This is the look at the top of the jib. To me it looks as though the sail should be taller. I have more than 2.5' of extrusion visible. Should the leach be more or less in-line with the mast is the sail is a jib? This sail is not more than 100%.
